Knock sensor detection via MUT
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
It seems to me that MUT_72 logs if the Knock is actually present, this is bit0.
The second thing what it logs is if it is in fade out phase that is bit1.
0 - no knock
1 - knock
2 - no knock but decay time - ignition still affected from previously detected knock
3 - knock + decay time timer running
Can anyone confirm?
I will try to log it, hopefully I will get some knock
0 - no knock
1 - knock
Can anyone confirm?
I try to locate the same in some of well known ROMs like 88590015 and get back with locations.
You said it backwards...maybe thats why no one listened,lol. JK. Its so cool that more and more disam guys are joining the quest to hack the ECU code. I'm dying to understand it completely but I really need my hand held the first time I'd say within a month we are going to have 100% control over the knock control stuff, with Tephra working on a 3D knock map and with the level of ignition retard now user adjustable people will be able to keep their cars in their 'tuned groove' a lot more often
On 96530006 there is a big subroutine for knock starting at adr 26360 - however I got lost....
Howoever - MUT72 logs FFFF8A0B; but in the dissassembly - some knock dynamics goes into FFFF8A0A - so we need to log 8A0A as well as another MUT. Am I right?
My IX has pulled timing from one count of knock numerous times and at 3+ counts my pull is shot, car falls flat on its face.......my previous VIII was much more sensible when it came to knock vs. retard.
yeah but that is a pretty big maybe.......im inclined to think mitsu made the knock control a bit pickier in the evo IX for one reason or another. Nice thing - its all about to become a non-issue...
Has anyone found any evidence that the ECU uses finer increments than 1 degree? Just curious if it interpolates enough to maybe be using 0.1 degree or some other increment? This would explain those who see timing move for 1 knock.
