96940011 And P0300 Codes..
I tried searching, but didn't really come up with much.
My car with it's fresh rebuild is occasionally throwing P0300's now because of a noisy clutch. (No knock has been recorded/logged yet.
Is there a defined way to get rid of the P0300 yet on the 96940011's?
As soon as I get an answer I will have the thread closed/deleted as to not clutter up the Ecuflash forum..
Thanks all.
P.S. Does switching to the other ROM work? Bryan (Razorlab?)
Thanks all.
tkk, I only saw the P0300 code 2 or 3 times when I used the 0011 ROM and never after my clutch install. I switched to the 96530006 ROM months back and have had no ill effects and not one P0300. Worth a shot.
I am thinking that that is what I need to do.
Any chance you could send me a few things to help me get a jump on it?
All the files I would need to get it going?
I think I would need the EvoScan data file, the .xml for the rom, and the actual map file.
I feel so bad asking for this stuff, but after three months of not having a car to tune/play with/tryout stuff on, I am very far behind..
When I got my car back from my Buschur build, I started getting the P0300.
I switched from the 0008 to the 0015 ROM and it has done the trick. I know it's hit or miss, but it seems to have worked for me.
Check out this thread:
https://www.evolutionm.net/forums/sh...37#post6280737
Damn, how the heck did I not find that? Haha!
I am going to make the switch to the new ROM, and report back. Hopefully I won't run into any hiccups. Last night I fixed my O2 sensor problem, so I should be good to go to start her up and put a few miles on her today after work.
8-BallEvo
Aug 3, 2010 08:55 PM
boostedscooby 5
21
Oct 2, 2009 03:51 PM
