EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Sep 22, 2011 | 02:55 AM
  #1711
evoscan's Avatar
Silver Sponsor
tactrix cable is not supported as per the website. only the EvoScan OpenPort 1.3U and EvoScan OpenPort 1.3R cables are supported for read/flash ECU. and only specific ecu's are supported. All this information is available on my website at the webpage: http://www.evoscan.com/free-ecu-rom-downloads
Last Table and last column at the bottom of the page
Cable Model Chipset Vendor ID Product ID USB Descriptor Includes ChipID
Serial for ECUFlash EvoScan
Datalogging EvoScan Reflashing
OpenPort 1.0 FT232BM 0403 6001 USB Serial Yes Yes (+gps=TBC) No
OpenPort 1.2 FT232BM 0403 6001 OpenPort 1.2 Yes Yes (+gps=TBC) No
OpenPort 1.3M FT232RQ 0403 CC48 OpenPort 1.3 Mitsubishi Yes Yes (+gps=TBC) No
OpenPort 1.3S FT232RQ 0403 CC49 OpenPort 1.3 Subaru Yes Yes (+gps=TBC)
No
OpenPort 1.3U FT232RQ 0403 CC4A OpenPort 1.3 Universal
Yes Yes (+gps=Yes) Yes (+gps=Yes)
OpenPort 1.3R FT232RQ 0403 CC4A OpenPort 1.3 Universal No Yes (+gps=Yes) Yes (+gps=Yes)
OpenPort 1.3D FTDI 0403 TBC TBC No Yes (+gps=Yes) No
12Pin Mitsi FTDI 0403 TBC TBC No Yes (+gps=TBC) No
9Pin/16Pin Subaru FTDI 0403 TBC TBC No Yes (+gps=TBC) No
OpenPort 2.0 NXP TBC TBC OpenPort 2.0 Yes Yes (+gps=EvoX only) No
Old Sep 22, 2011 | 02:57 AM
  #1712
evoscan's Avatar
Silver Sponsor
Also if you are after MacBook support.. please read this web page on my website:
"What Operating Systems does EvoScan Support"
http://www.evoscan.com/helpdesk/know....php?article=2
Old Sep 22, 2011 | 05:45 AM
  #1713
SmurfZilla's Avatar
I'm trying with my windows machine tonight. I'm not sure if its a tactrix cable, how can i tell.
Old Sep 24, 2011 | 09:26 AM
  #1714
4ce fed's Avatar
So I'm confused about some of the functionality that this unit offers. Does this GPS unit also run ecuflash? I see that it can flash the ecu, but can I tune with it? If so, does it provide the same functionality as a laptop running evoscan and ecuflash?
Old Sep 25, 2011 | 02:44 PM
  #1715
SmurfZilla's Avatar
Battery low was part of the problem. I'll buy another cable today. If it works i will sell the one I currently have.
Old Sep 25, 2011 | 03:11 PM
  #1716
SmurfZilla's Avatar
Bought a 1.3U cable since it seems it allows me to do everything with the GPS unit (including clearing codes). I'll be posting my Tactrix for sale very soon.
Old Sep 26, 2011 | 11:48 PM
  #1717
evoscan's Avatar
Silver Sponsor
New EvoScan MMCFlash ECU Reflashing Software
https://www.evolutionm.net/forums/ec...-software.html
MH7201F (128k) - 1997 Space Wagon 2.4 GDI; Galant 4G93 GDI; Mirage Dingo 1.5 4G15 GDI;
MH7202F (128k) - The same model as the 7203 Mitsubishi, Mazda 626, 1998.
MH7203FA (128k) - Mitsubishi Carisma, Pajero, Eclipse, Galant 2000, 2004; Montero Pajero 3.2 DID 4m41 2002;
Hyundai Sonata 2.0 (Korea, Tagaz) 2004, Santa Fe 2.4 2001-2004, Tiburon 2.0 (Cupe), Matrix 1.8;
Kia Sorrento 2.4, Magentis 2.0 2000 2004;
MH8206F (256K) - Lancer IX MT
MH8305F (512K) - Lancer IX AT
Read and write Vehicle ECUs, MH8301F, MH8302F, MH8303F, MH8304F, MH8201F *NEW*
Supports recalculation of Mitsubishi ROM Checksum.
MH8301F (512K) - 2001 Montero Sport 3.5L; 2001 Pajero 3.0;
MH8302F (512K) - since 2004 Galant 2.4L MIVEC; Outlander 2003-2005; Outlander CU5W 2.4
AT MIVEC 07/05 - 12/08; from 2003 Montero Sport 3.5L 4WD; from 2004 Galant 3.8L V6; 06-09 Eclipse GT ;
MH8303F (768k) - from 2006 Outlander AWD AT; from 2006 Outlander 2.4L 4WD AT MIVEC;
MH8304F (512K & 768k) - from 2005 Galant 2.4L; Colt 1.3 2004-2008;
MitsubishiLancer X 1.5 and Outlander JDM (right hand drive)
Supports reading and writing ECU MH8104F
Mitsubishi EvoX ACD MH8104F
Mitsubishi LancerX 1.5 MH8104F
Mitsubishi Outlander (JDM) MH8104F
*new September 2011*: supports MH7201F Mitsubishi VR4, even those with external memory chips.
no need to resolder nor no more need to resocket the chips now! reprogram via the openport 2.0 cable.
Old Sep 27, 2011 | 06:52 AM
  #1718
evoscan's Avatar
Silver Sponsor
I am finalizing Virtual Dyno for EvoScan v2.9.10 MapTracer
Am I missing any important fields that you guys are using?
and are they in the right order of your preference? (they are not case sensitive)
WideBandAF, AFR, WideBand, LC1AFR, AEMWideBandAF, WB-AFR, WB02, AFRMAP, ZTXWideBandAF, WideBandLM, WDB
Boost, MAP, JDMMAP, GMMAP, ZTXBoost, PSIG, OMNIMAP, 4bar-map
RPM, 2ByteRPM, RPMMUT2Byte
LOAD, LOADMUT2BYTE, LOADCALC, ENGINELOAD, ABSOLUTELOAD, LOAD160, ECULOAD, LOAD11BIT4, LOAD1B, ABSLOAD, ACCLOAD, LOADMIVEC, LOADLOWIATSTIMING, LOADFUEL
Old Sep 27, 2011 | 08:42 AM
  #1719
Danieln's Avatar
Hi Hamish,
Any news about LM-2 support in the future?
What do you need from them in order to implement LM-2 support in Evoscan?
Cheers
Old Sep 27, 2011 | 11:29 PM
  #1720
evoscan's Avatar
Silver Sponsor
Added support for reflashing Yamaha JetSkis using OpenPort 2.0
http://www.evoscan.com/evoscan-gps-o...aha-reflashing
MMCFlash software for Yamaha ECU Reflashing.
supports the following ECUs MH8102F, and MH8104F
Yamaha F40/50/60 MH8102F (ECU is not filled).
Yamaha RFX nitro MH8104F (ECU filled).
Old Sep 27, 2011 | 11:59 PM
  #1721
And's Avatar
And
can you remove all unselected items from the saved logs?
Old Sep 28, 2011 | 01:45 AM
  #1722
evoscan's Avatar
Silver Sponsor
no, removing all unselected items from the saved logs does not make sense.
EvoScan is unique, in that it allows the user to tick and untick items during logging.
This means the log file can not ahead of time predict the users actions for items to be logged. hence all columns are present.
I could add an option to the EvoScan Logging menu that when ticked, will post-process any log file, and removes all blank columns if you want? It will consume more I/O, battery and cpu to do this after each time you press stop datalogger.
Old Sep 28, 2011 | 01:59 AM
  #1723
And's Avatar
And
would be useful as when I view the csv files I have to hide all of the empty items, although I guess I could rearrange the items so the ones I want are at the top of the list so appear at the begining of the csv file
Old Sep 28, 2011 | 05:00 PM
  #1724
4ce fed's Avatar
Anyone?
Old Sep 29, 2011 | 12:09 AM
  #1725
nudge120's Avatar
Anyone?
No you can't change any parameters with the GPS, you just load the rom onto the GPS and then you can flash it to the ECU. Also you cannot read the logs on the GPS it will only give live reading with the gauge function, but it does have peak and hold.
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
