EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Jan 28, 2012 | 02:19 AM
  #1771
evoscan's Avatar
Silver Sponsor
New Features for EvoScan v2.9.0017 released 28th January 2012:
- Automatic updates via internet and new tips at startup.
- Added support for wideband Zeitronix ZT2 2010 model (includes user2 input)
- Added support for wideband Zeitronix ZT3 model (includes user2 input)
- Added support for wideband AEM UEGO inline model (19200 baudrate)
- Added support for wideband AEM UEGO usb/xwifi model (115200 baudrate)
- Added support for DLP-IO8 8x channel Analogue 0-5Volts and Temperature to Digital USB adapter
- Added Live Virtual Road Dyno (similiar to VDR5.6Excel and VirtualDyno, thanks Brad for some drag coefficients)
- SEE your live Power/Torque curve whilst you are driving... it looks for Throttle Position > 80 or Accelerator Pedal Position >80.
- ADDs a new Power/Torque run in the panel each time you put your foot to the floor... TPS > 80 or APP > 80.
- NEW wheel/hub dyno power setting feature that excludes wind resistance drag calculation so you can see the live Power/Torque curve when on the dyno.
- Added support for Map Tracer hide/display view panels Ctrl+1, Ctrl+2, Ctrl+3, Ctrl+4, Ctrl+5, Ctrl+6 for each of the 6 panels.
- Panel6 is realtime line charts, and can also load and compare up to 2 saved csv logs at once.
- Added support for Map Tracer map editor smoothing shortcuts Ctrl+Plus key, Ctrl+Minus key.
- Added support for Media Centre Remote Control to edit map files in maptracer screen
- Added support for Map Tracer live tracking BLUE crosshair
- Added support for Map Tracer live data graphs
- Added support for Tephra EvoX Mod ecu ROM datalogging speed enhancements
- Added support for Maptracer trim filtering slider bar
- Increased reliability and speed for EvoX datalogging
- Added support for EvoX ECU reset learned Fuel Trims
- Added support for EvoX Actuator support
- Added support for more 2011 EvoX mode23 vehicles, thanks Golden.
- Added CeddyMods EFI xml files.
- Added more DataSetting xml files for new Mitsubishi EvoX models
- Increased reliability and speed for Diagnostic Trouble Code Reading EVOX EFI
- Increased reliability and speed for Diagnostic Trouble Code Reading OBDII DTC
- Increased reliability when the user accidentally deletes the original EvoScan MSI installer
Known Issues:
- Some Galant 2001 vehicles the DTC does not display. work in progress.
- TephraMod Live Tuning is still work in progress.
- Endian="little" on a couple of the evo5 xml scalings does not load the rom table correctly. work in progress.
- PLX wideband is not supported. work in progress.
Old Jan 28, 2012 | 02:22 AM
  #1772
evoscan's Avatar
Silver Sponsor
Let me know if you want anything fixed up with the new v2.9 release, and I'll be able to send new patches via the EvoScan "check for updates".
Thanks to all the beta testers that worked hard on this release. some even provided up to 20+ pages of screenshots
Old Jan 28, 2012 | 02:55 AM
  #1773
nonschlont's Avatar
saaawweeeeeeeeeet!!! Looking forward to upgrading...
Congrats and Thank You on the new release!!!
Old Jan 28, 2012 | 08:04 AM
  #1774
dolphin888's Avatar
Question
Two questions:
1) Why are "move up" and "move down" buttons missing in EvoScan Edit Data Settings?
2) Will be OP2.0 supported for reflash later?
P.S. Never mind about the first one, ctrl+up/down is very convenient!
Old Jan 28, 2012 | 11:05 AM
  #1775
GregM's Avatar
Am I blind, or is ZTX User2 not shown?
Old Jan 28, 2012 | 11:15 AM
  #1776
evoscan's Avatar
Silver Sponsor
Originally Posted by dolphin888
Two questions:
1) Dolphin, have a read of all the tips at startup. it is mentioned in there some other cool method of moving the data items up and down.
2) yeah I can look into op2 reflash support for you. never really considered it because 1.3U cables are cheaper and faster for Evo7/8/9 reflashing.
Old Jan 28, 2012 | 11:17 AM
  #1777
evoscan's Avatar
Silver Sponsor
Good spotting. not sure where I put that one just add a new data item and put in the LogReference field "ZTXUser2" and it will work. Send me a support call if you can't get it working.
Old Jan 28, 2012 | 11:21 AM
  #1778
GregM's Avatar
Thanks, will give it a try this morning
Old Jan 28, 2012 | 12:04 PM
  #1779
dolphin888's Avatar
What can I say... drag 'n drop method is awesome!
I really need OP2.0 support, I thought it will be implemended by default What do you need from me to make that support?
P.S. Donation sent
Old Jan 28, 2012 | 12:27 PM
  #1780
evoscan's Avatar
Silver Sponsor
P.S. Donation sent
firstly thanks for the donation, much appreciated
It most certainly does have op2 support for datalogging.
if you want op2 support for reflashing we use ecuflash.
There is a huge variance of supported cables and vehicles to list on here. Use this matrix to determine supported vehicles and cables:
http://www.evoscan.com/mitsubishi-su...bd2-can-cables
Old Jan 28, 2012 | 12:35 PM
  #1781
evoscan's Avatar
Silver Sponsor
These are the OpenPort 2.0 features supported in EvoScan v2.9
OpenPort 2.0 OBDII EFI -> Read DTC - YES
OpenPort 2.0 OBDII EFI -> Clear DTC - YES
OpenPort 2.0 OBDII 96+ -> DataLogging - YES
OpenPort 2.0 MUTII EFI -> DataLogging - YES
OpenPort 2.0 CAN OBDII -> DataLogging - YES
OpenPort 2.0 CAN MUTIII -> DataLogging - YES
OpenPort 2.0 CAN EvoX Mode23 -> DataLogging - YES
OpenPort 2.0 EvoX ECU Learn Reset -> Activate - YES
OpenPort 2.0 EvoX SST Auto Transmission -> DataLogging - YES
This list is kept up to date on this webpage
Old Jan 28, 2012 | 12:48 PM
  #1782
dolphin888's Avatar
I use it as well, but I really need OP2.0 reflash support in EvoScan. Can you do it for me? I'm tired to switch between two programs for years... I hope sooner or later there will be such possibility.
P.S. I had 1.3U several years ago, as soos as OP2.0 production started, I have sold 1.3U and bought 2.0. I want to use one op interface and one software, it's inconvenient to use severalsoftware or cables.
Old Jan 28, 2012 | 12:49 PM
  #1783
evoscan's Avatar
Silver Sponsor
Add this to your Documents\EvoScan v2.9\DataSettings\ xml file
Code:
<DataListItem DataLog="N" Color="" Display="ZTX User2" LogReference="ZTXUser2" RequestID="ZTX" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
And to use ZTXUser2 ensure you tick the "Zeitronix ZT2/ZT3 2010 Model" selected from the EvoScan wideband menu.
Old Jan 28, 2012 | 12:51 PM
  #1784
evoscan's Avatar
Silver Sponsor
If I had an Evo8 I would just use a 1.3U cable, it is supported by more software, and has more features for Evo8. Sell your op2 and get a 1.3u
Old Jan 28, 2012 | 01:04 PM
  #1785
dolphin888's Avatar
I hope to see op2.0 reflash support sooner
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
