EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#1786
Congrats on the new version. Is there any actual plan for an iPad release? There are a couple of dead threads about that question unanswered, and my support emails also unanswered. Just want to know as I am planning a new setup for convenient and continuous logging.
#1787
evoscan 2.9.0017 disconnect automatically
Hello,
Thanks to Hamish, finally I could install and test mode23 logging with this brand new 2.9.0017 today. Great improvements! I donated via PayPal.
Hamish, I have a trouble : EvoScan 2.9.0017 automatically disconnects logging. This is very troublesome so I want to solve it as soon as possible.
I found one condition, when I release ( or loosen ) my accel pedal, EvoScan 2.9.0017 disconnects logging ( and never reconnects automatically again ).
This unexpected auto disconnect occurs while idling, too. When my car is idling, EvoScan 2.9.0017 seems to disconnect logging randomly.
I assume that it is related to throttle sensor reading but not sure.
Hamish, could you please help me?
#1788
sorry for newbie question, what does this message mean?
I don't understand what "cap at 485nm" means,though it seems to show some kind of logging speed limit for developer...
#1789
Silver Sponsor
It could just be PC related, you have PM, I will check it out for you.
that notes field relates to which ever data item you have selected in the left hand side. you might be selected on EvoX EFI Engine Torque calculation? it is true for that data item from the ecu, it is capped at 485nm due to internal Mitsubishi ecu calculation limitations.
#1790
Hello,
Hamish, thank you for your help.
Ummm...I don't know about "EvoX EFI Engine Torque calculation" at all. Is there any instruction/explanation/manual about it?
Attached is a pic of my EvoScan screen. I was selecting "EVOX EFI". No need to select it for usual logging?
My components : Windows 7 ( 32 bit ), LC-1 w/ USB-TO-Serial adapter.
#1792
I have just found a bug. It's not possible to log Injector Duty %, it's always a zero. Yes, I have selected Injector Pulse Width (this one is working). While tryng to log Injector Duty %, "No Response from Vehicle ECU" can be seen in Notes screen on the right.
Can it be related with the fact, that I have edited Data Settings several times?
#1793
I found TPS is shown as deg instead of % and ZTX Boost Response is 38 instead of ZTX.
#1794
About TPS: if we look at EvoScan v2.8, we can see, that TPS data settings are the same, just units are "%" instead of "Degrees".
Moreover, I have noticed, that with v2.9 I get a slightly slower logging speed, than with v2.8, it feels a little bit laggy. With "Disable Multithreading" checked it's much better, although...
#1795
Silver Sponsor
lol, it doesn't feel laggy. it just looks laggy, because the UI isn't keeping up with the Faster logging speed . check your csv logs, you'll find its logging more data at a faster speed. In fact turn off log to screen will give you another performance boost. With "disable multithreading" checked, will actually slow you down.
#1796
Silver Sponsor
Crimson_Red I will also include your 2010 EvoX mode23 requestids. It might be the way you have edited your xml file to include the missing mode23 requestids, I'll look at it a bit closer.
#1797
I hadn't any chance to do some logs to file yet Played with new version only once...
#1799
Thanks Greg, I'll correct this and a few other minor xml things in the next auto update.
