EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Feb 3, 2012 | 01:00 AM
  #1801
crimson red's Avatar
Attached. if you find any mistakes or places can be improved, please tell me. I'm very glad.
Originally Posted by evoscan
yep, post it here. or email it to evom at evoscan.com
thanks.
File Type: txt
Old Feb 4, 2012 | 04:39 AM
  #1802
evoscan's Avatar
Silver Sponsor
So, what do you guys think of EvoScan v2.9.0017 so far? Got any screenshots of any cool power curves?
Old Feb 4, 2012 | 10:58 AM
  #1803
GregM's Avatar
Everytime I start Evoscan I need to select my wideband, it use to remember which one I used previously. Its running pretty great for me so far other than that. I'll have to get one of those DLP-IO8's of you and give that a try
Old Feb 8, 2012 | 10:06 PM
  #1804
evoscan's Avatar
Silver Sponsor
yeah sorry, it does that for the two new widebands I added in the dropdown, I'll fix that up in the next update shortly.. the workaround is to just select the wideband each time you open EvoScan v2.9.0017
Old Feb 10, 2012 | 01:24 AM
  #1805
evoscan's Avatar
Silver Sponsor
thanks, I included this. and I also added some more dataitems to EvoX datalogging in the new EvoScan version released today.. EvoScan v2.9.0018
Old Feb 14, 2012 | 02:06 AM
  #1806
evoscan's Avatar
Silver Sponsor
a reminder for those using the older v2.9 beta versions, please upgrade to v2.9.0018, some people are still logging bugs related to the beta versions only.
  #1807
evoscan's Avatar
Silver Sponsor
oh and don't forget to clear out your Documents\EvoScan v2.9\ if you are trying to do a clean install.
Old Feb 20, 2012 | 09:00 PM
  #1808
evoscan's Avatar
Silver Sponsor
Updated EvoScan v2.9.0019
- Fixes for xml Auto Updates.
- Fix for bug introduced in v2.9 by mistake.. fixes datalogging dropouts due to LC-1 o2% level and the same bug effected some scenarios for DLP-IO8 Datalogging.
- Added more Mode23 EvoX xml files
- if you want any xml files updated with other request ids or formulas, or the default dataitem order changed.. send me a message and i'll add it to the xml files for you.
- More support for loading roms and ecuflash xmls files into evoscan for map smoothing and map ediitng, and evo7/8/9 reflashing via EvoScan.
- Note: MapTracer has all the latest EvoScan graphing.. scroll to the bottom of the Maptracer screen.
New Features for EvoScan v2.9.0017 released 28th January 2012:
- Automatic updates via internet and new tips at startup.
- Added support for wideband Zeitronix ZT2 2010 model (includes user2 input)
- Added support for wideband Zeitronix ZT3 model (includes user2 input)
- Added support for wideband AEM UEGO inline model (19200 baudrate)
- Added support for wideband AEM UEGO usb/xwifi model (115200 baudrate)
- Added support for DLP-IO8 8x channel Analogue 0-5Volts and Temperature to Digital USB adapter
- Added Live Virtual Road Dyno (similiar to VDR5.6Excel and VirtualDyno, thanks Brad for some drag coefficients)
- SEE your live Power/Torque curve whilst you are driving... it looks for Throttle Position > 80 or Accelerator Pedal Position >80.
- ADDs a new Power/Torque run in the panel each time you put your foot to the floor... TPS > 80 or APP > 80.
- NEW wheel/hub dyno power setting feature that excludes wind resistance drag calculation so you can see the live Power/Torque curve when on the dyno.
- Added support for Map Tracer hide/display view panels Ctrl+1, Ctrl+2, Ctrl+3, Ctrl+4, Ctrl+5, Ctrl+6 for each of the 6 panels.
- Panel6 is realtime line charts, and can also load and compare up to 2 saved csv logs at once.
- Added support for Map Tracer map editor smoothing shortcuts Ctrl+Plus key, Ctrl+Minus key.
- Added support for Media Centre Remote Control to edit map files in maptracer screen
- Added support for Map Tracer live tracking BLUE crosshair
- Added support for Map Tracer live data graphs
- Added support for Tephra EvoX Mod ecu ROM datalogging speed enhancements
- Added support for Maptracer trim filtering slider bar
- Increased reliability and speed for EvoX datalogging
- Added support for EvoX ECU reset learned Fuel Trims
- Added support for EvoX Actuator support
- Added support for more 2011 EvoX mode23 vehicles, thanks Golden.
- Added CeddyMods EFI xml files.
- Added more DataSetting xml files for new Mitsubishi EvoX models
- Increased reliability and speed for Diagnostic Trouble Code Reading EVOX EFI
- Increased reliability and speed for Diagnostic Trouble Code Reading OBDII DTC
- Increased reliability when the user accidentally deletes the original EvoScan MSI installer
Known Issues:
- Some Galant 2001 vehicles the DTC does not display. work in progress.
- TephraMod Live Tuning is still work in progress.
- Endian="little" on a couple of the evo5 xml scalings does not load the rom table correctly. work in progress.
- PLX wideband is not supported. work in progress.
Old Feb 28, 2012 | 02:19 AM
  #1809
toeng's Avatar
Hi, Could anyone explain me what is the Interpolated target calc in the Evoscan and how its valve come from?
Thanks in advance
Old Feb 28, 2012 | 05:45 PM
  #1810
SilverJesterGSX's Avatar
Does v2.9 add peak and hold gauge capability? If so how do I make my virtual gauges have this functionality?
Old Mar 2, 2012 | 12:16 PM
  #1811
dolphin888's Avatar
http://img3.imageshack.us/img3/5783/loadnrpm.jpg
Anybody has seen this before? I have tried to make a fresh v2.9.0019 install on two different laptops with different OS. With v2.9.0017 never seen these strange load and rpm values
Edited: I noticed, that some other hex ROM files looks ok, so I decided to throw that ROM file into ecuflash folder, where xml's are kept. That worked for me.
Old Mar 2, 2012 | 03:44 PM
  #1812
evoscan's Avatar
Silver Sponsor
Good thinking, the load xml search order for rom in MapTracer screen is
- current folder search for xml
- evoscan roms folder for xml
- ecuflash rommetadata folders for xml
Old Mar 2, 2012 | 03:49 PM
  #1813
evoscan's Avatar
Silver Sponsor
it is to do with an old xml that probably has the wrong endian format in the xml metadata file. v2.9.0019 is best, it loads endian correctly.
download your rom xml from www.evoscan.com/roms/mitsubishi for the latest xmls, you might have an old xml file.
Old Mar 2, 2012 | 04:18 PM
  #1814
dolphin888's Avatar
Thank You for comments.
I'll try to look into my xml, not so good part of it is that my personal car xml is sooooo many times edited, that is hard to understand what has been done through years
By the way, why it has started working well with the same xml, when I moved the ROM file?
Old Mar 2, 2012 | 11:51 PM
  #1815
HAMISH, For justice, I will not overlook this fact.
Hamish,
I found that the file "Mitsubishi EvoX Mode23 JAP_AU_EU.xml" ( evoscan 2.9.0019 installer installs it. ) includes whole of my personal definitions and comments for 2010 JDM EvoX. The content is exactly as same to my personal .xml file I've never sent to you.
There're many evidences in the xml :
1. This comment is written by me for my personal memorandum. Why is it installed with evoscan 2.9? :
Code:
      00100010: 34
      00100000: 32
      10100010:162,
      10100110:166 -->
2. These items are my personal test items : "AC ON((bit5) and Brake Pedal(bit0)", "MUT_MANY", "MUTD1"
3. These items were presented to me by Golden and tephra personally and not released for 56180002 to public yet. : "MAFCalcs", "MAPCalcs".
4. These items were presented to me by Golden personally and not released for 56180002 to public yet. :
"knock_adc_processed", "knock_base", "knock_var", "knock_change", "knock_dynamics", "knock_flag".
As I posted #1799, I'VE NEVER sent my .xml file to you. How did you got my file(s) without me? What did you do when you operated "team viewer" you requested me to install for check the bug of evoscan 2.9 ?
Hamish, what you did to me is extremely violated as human behavior. Delete my personal texts except for items which I posted at #1801 from your installer ASAP.
Everyone of the community, I am truly, so sorry. I didn't want to write such a thing...
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
