EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#1863
EvoScanPPCGaugeDesigner question
I can't seem to get the MarkLog ActionButton to work!
The Mark Log button works fine on the main Logging Screen, but when I define a button on a gauge screen, pressing the button doesn't place a mark in the log. Not sure what I'm doing wrong for this one button, everything else on the screen works as expected?
Here is a copy of my Gauge template file:
I am using the latest versions of both the EvoScanPPC and EvoScanPPCGaugeDesigner executables. The last ActionButton in the above template is the one I'm having difficulties with. I've tried all sorts of things, moving to different locations, using different background images, changing offset etc. Nothing seems to work.
help?
Thanks,
John-
Code:
// EVOSCAN GAUGE 1 by Hamish Ahern (c) 2010 EvoScanPPC (PocketPC/WinCE/WindowsMobile) //================================================================================================================================= // Copyright 2010 (c) Limitless Designs Ltd www.evoscan.com // You can freely edit this file, and distribute this template freely on the internet for use with EvoScanPPC only. // if you see // at the beginning of the line, this is just a comment only line and any blank lines also are ignored. // also any number of spaces before or after a comma (,) are ignored, so it doesn't matter how many spaces or tabs you use to make gaps. // CaPiTaliZation also doesn't make any difference, you can type yes or YeS or Yes or YES, and it will still work ok. //--------------------------------------------------------------------------------------------------------------------------------- Minimum EvoScanPPC Version, v2.2 //================================================================================================================================= //BACKGROUND IMAGE: use png files, because this is the best quality image, needs to be in \EvoScanPPC\images\ folder on the sdcard // The Background image should be 480x272 480 pixels for the width, and 272 pixels for the height. // PNG file format is the best quality image format for gauges, //--------------------------------------------------------------------------------------------------------------------------------- BackgroundImage,EvoScan1.png NumericGauge,Left Top,KnockSum,1,183,180,42,Yes,KnockSum,12,5,20,Yes,,12,30,14,Far,48,0,Max,100,24,28,Near,, NumericGauge,Left Bottom,LC1_Wideband,1,227,180,42,Yes,Wideband,12,8,20,Yes,,12,30,14,Far,48,1,No,100,22,26,Near,, NumericGauge,Right Top,CoolantTemp,271,183,190,42,Yes,Coolant Temp,12,5,20,Yes,,12,30,14,Far,48,0,Max,90,24,28,Near,, NumericGauge,Right Bottom,4-Bar,271,227,190,42,Yes,Boost,12,8,20,Yes,,12,30,14,Far,48,0,Max,90,22,26,Near,, NumericGauge,Speed,Speed,328,109,90,38,No,,0,0,20,Yes,,-8,3,14,Center,42,0,Max,61,-39,42,Near,, NumericGauge,STFT,O2FeedbackTrim,125,70,80,42,Yes,STFT,7,3,20,Yes,,2,15,14,Far,48,0,No,100,22,26,Near,, NumericGauge,Timing,TimingAdv,253,7,57,50,Yes,Timing,0,-10,20,Yes,Deg,10,40,14,Center,45,0,No,50,0,40,Near,, CircularGauge,Throttle,TPS,77,79,172,68,44,0,100,,Yes,198,0,75,171,255|127|80|3,Yes,,,, CircularGauge,Speed,Speed,373,97,85,-90,260,0,260,GaugeParts/EvoScan1_Cap1.png,Yes,0,0,480,272,255|127|80|3,No,,,, CircularGauge,RPM,RPM,97,68,58,-90,180,0,8,GaugeParts/EvoScan1_Cap2.png,Yes,0,0,480,272,255|127|80|3,No,,,, CircularGauge,Fuel Usage,FuelConsumption,97,165,67,-90,180,0,100,,Yes,0,0,480,272,255|127|80|3,No,,,, CircularGauge,Battery,Battery,80,244,178,66,48,0,16,,Yes,198,170,74,98,255|127|80|3,Yes,,,, ActionButton,BrightnessUp,GaugeParts/MyGauges1_BU.png,BrightnessUp,6,6,35,41,0,0,, ActionButton,BrightnessDown,GaugeParts/MyGauges1_BD.png,MarkLogPoint,6,60,34,41,0,0,, ActionButton,BtnClose,GaugeParts/MyGauges1_X.png,Close,440,6,48,41,0,0,, ActionButton,MarkLog,GaugeParts/MarkLog.png,MarkLogPoint,440,155,37,37,2,2,,
help?
Thanks,
John-
#1864
Silver Sponsor
#1865
New EvoDroid7 GPS Navigator, features here
#1866
The change log for v2.5 (and GaugeDesigner v2.5) says it was added:
13 January 2012 - EvoScanPPC v2.5 Download Here. (includes Gauge Designer v2.5)
• Aligned version numbers between EvoScanPPC/GPSNav and GaugeDesigner.exe which makes it easier to know which versions support the required features.
• Added new Action options to ActionButtons for gauges...
- EvoXecuReset will work with OpenPort 2.0 and EvoX, pressing it reset the learned fuel trims on next key off/on. Vehicle must be connected and datalogging on the gauge screen for this EvoXecuReset button to work.
- Start New Log / Mark Log Point / End Log buttons added to v2.5 gauges as per request from JohnnyTSi on evolutionm.net forums.
#1867
Add this to your Documents\EvoScan v2.9\DataSettings\ xml file
And to use ZTXUser2 ensure you tick the "Zeitronix ZT2/ZT3 2010 Model" selected from the EvoScan wideband menu.
Code:
<DataListItem DataLog="N" Color="" Display="ZTX User2" LogReference="ZTXUser2" RequestID="ZTX" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Also I have a problem with the turbo pressure, I can't read in Bar but only in PSI.
Thanks Hamish.
#1871
http://camstudio.org/ have you tried this already?
#1872
No, I haven't, but its not quite what I'm looking for.
Trackvision allows raw log files to be used and gauges displayed on the video. Evoscan isn't one of the compatible formats, and so far have not found any software like this which will work with Evoscan.
Evoscan has a tab for Video and GPS, but its been on many versions saying its in beta, but there is no functionality. Is this still going to happen Hamish?
#1873
Silver Sponsor
EvoScan v2.9.0023 Released - AUTO UPDATE or download the updated installer from here using your evoscan login.
- Increased display speed to cater for up to 700samples/sec for EvoX RAX logging
- NEW DataSettings file for Mitsubishi EvoX Mode23 RAX Patch.xml
- Fixed random unticking behind the scenes, now only applies to sst temp nonresponse.
- Added Datasetting xml option for LogHide, allows items to be datalogging on the screen but not logged to file.
- Added Datasetting xml option for PriorityOffset, allows items to be datalogging at a different offset to ensure smooth logging at high speed.
- Map Tracer now displays the grid items in the middle of each CELL to make it easier for tuning the maps.
- Power/Torque graph no longer pops up the annoying missing >80% Throttle message now, users will just have to make sure to log TPS >80% if they want power graphs.
- Numerous fixes and performance improvements.
RAX EVOX Fast Logging
https://www.evolutionm.net/forums/ec...t-logging.html
or evoxforums /forums/showthread.php?t=70705
#1874
I have the zeitronix pressure turbo, exhaust, AFR, and oil temperatures. everything works except there is no oil temperature signal.Also i have the same problem boost.
Can anyone help?
I wrote an email to Amish but I did not answer.
Amish please reply here
#1875
Hey guys,
Anyone know how to contact Hamish? I hope he still comes on this forum. I am looking to get my hands on the Evoscan GPS NAV but I noticed on his website you can't seem to order one.
Also, the iPad connect product he has on display for Evoscan is also unavailable...
I am looking to get it for my VR4.
Thanks.
Thanks.
