EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#407
From: Tallahassee, but currently reside @ Camp LeJeune
so is this ready then for me to order to log my Evo X now if so, ill register asap, and i have the tactrix 2.0 for my eco flash, will that cable work for this as well
#413
how come there no dowload tab no where on that site for people that allready have the older version.
something like upgrade click here or enter the your serial number for the latest version of evo scan.
#415
EvoX new datalogging values for beta10!!!! oh yeahh!! I'm sure I can come up with more too.
2008/09 EVOX EFI ECU:
Battery Voltage
Idle RPM
Vehicle Speed
Intake Sensor 44 deg c
Coolant Sensor 68 degC
MAP Sensor 102.4kpa
Airflow Sensor 1171.9 mV
APS Main 996.1 mV
TPS 722.7 mV
TPS max 4375.0mV
TPS(main) learn 859.4mV
TPS(sub) 4257.8mV
Ignition Advance 61CA
Injection Time 0.0ms
LTFT Bank1 -1.2%
STFT Bank1 0.0%
Knock Retard 0.0CA
Knock Learn 100%
VVT Intake 15.0CA
VVT Exhaust -25.0CA
Purge Relay Duty 0.0%
Throttle Actuator 6.7%
ETV Idle Open 0.7V (electronic throttle valve?)
ISC Learn (A/C off) 0.0 L/S
ISC Learn (A/C on) 0.0 L/S
Absolute Load 0.0 %
Accelerate Load 0.0%
Crank Signal Off
Airflow Sensor 0.40g/s
Front 02 Sensor 0.000V
Rear 02 Sensor 0.000V
APS 102 kPa
TPS relative 6.7%
TPS sub
APS Main 19.6%
APS Sub
Fuel Status 1 0LRV
Read/Clear EFI Trouble Codes
2008/09 EVOX ABS ECU
Longitudinal G-Sensor 0.000G
Horizontal G-Sensor 0.022G
Yaw Rate sensor 0.0
Brake Level Switch NORMAL
Engine RPM 0.0 rpm
Engine Torque 0.0Nm
Expected Gear Value D N R
Current Gear Value R D
Brake Sensor OFF
Horizontal G-Sensor Offset Value -0.007G
CVI Oil Temp
Primary Gear Speed 4096 r_min
real engine torque
correct engine torque
input torque
gear position 1st
Read/Clear ABS Trouble Codes
Battery Voltage
Idle RPM
Vehicle Speed
MAP Sensor 102.4kpa
APS Main 996.1 mV
TPS 722.7 mV
TPS max 4375.0mV
TPS(sub) 4257.8mV
LTFT Bank1 -1.2%
STFT Bank1 0.0%
Knock Retard 0.0CA
Knock Learn 100%
VVT Intake 15.0CA
VVT Exhaust -25.0CA
Absolute Load 0.0 %
Crank Signal Off
APS 102 kPa
TPS relative 6.7%
TPS sub
APS Main 19.6%
APS Sub
Fuel Status 1 0LRV
Yaw Rate sensor 0.0
Engine RPM 0.0 rpm
Engine Torque 0.0Nm
Brake Sensor OFF
CVI Oil Temp
real engine torque
input torque
gear position 1st
