EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#587
[QUOTE=Kakihara;6975833]Hi I'm really interested in the GPS touchscreen item 1) what gps software do you currently provide with the touchscreen ?
Both iGo8.0 and Garminx Mobile XT
2) how do the various maps work because I'm going to need several european countries maps : switzerland where I live but also germany,france,italia because I'm gonna use the GPS to go to various race tracks there (bresse & nurburgring nordschleife to name a few)
If you are referring to GPS Lap Timer, it is not supported yet. If you were referring to GPS navigation, you can load any countries map in it.
4) what are the limitations of that version compared to evoscan on a portable pc ? for example can I connect a wideband to it or no ?
Not supported yet, lots of limitation. Eg: No wideband for now, limited gauge display, OP2.0 not support yet.
Go with GPS, it come with evoscan for your laptop.
#588
Feature request: When you look at a graph and you hoover your mouse over a point in the graph it shows you the values at that current point. I would like to be able to do the same thing by dragging a line through the graph, or clicking on the graph and having that little box stay in place (like how logworks or AEM logger does it). It would make it much easier to analyze the data.
#591
Good day all,
I just received my Evoscan GPS today and Im still playing around with it. I skimmed through the past pages and couldnt find information about changing the gauges layout or gauge look. Is there a way to do that?
Thanks!
Thanks!
#592
Only 1 gauge up to date, Hamish said more be added soon.
#593
[QUOTE=sub7;6979374]
2) I was referring to me not being lost on the road going there not the GPS lap timer heh
Thank you sub7 for your answers
#594
From: Tallahassee, but currently reside @ Camp LeJeune
I was goofing around, just doin some test runs/logs to see how the evoscan program worked, first time using it ever and being that its not complete for the Evo X yet, had no expectations, just wanted to see the gist of it, i noticed some items weren't checked, so as the program was running, i checked all items and every started logging, my question is, are those items that were not initially checked not calibrated yet for the X/Evoscan potion of the program yet even though it logged all items setup in the program?
#595
#597
#598
With logworks anywhere you click it places a line and a box pops up and stays there showing you the values at that point.
With AEMlog you can drag a line through the graph and it shows you the values at that point in the box on the right.
#599
Hamish, In EvoScan there is an Injector Scaling box that says 513 for stock. If injectors are changed, does this have to be changed, as well? I have not before and I reviewed the Data.xml and do not see a reference to this. Is this a viable field?
