EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Apr 29, 2009 | 10:33 AM
  #601
GST Motorsports's Avatar
Originally Posted by fixem2
Hamish, In EvoScan there is an Injector Scaling box that says 513 for stock. If injectors are changed, does this have to be changed, as well? I have not before and I reviewed the Data.xml and do not see a reference to this. Is this a viable field?
Only if you are logging calculated load, if you are logging 2byte load, it doesn't matter.
Old Apr 29, 2009 | 11:01 AM
  #602
crcain's Avatar
Originally Posted by rabishi
feature request: when you look at a graph and you hoover your mouse over a point in the graph it shows you the values at that current point. I would like to be able to do the same thing by dragging a line through the graph, or clicking on the graph and having that little box stay in place (like how logworks or aem logger does it). It would make it much easier to analyze the data.
+1
Old Apr 29, 2009 | 11:03 AM
  #603
xbox4414's Avatar
Is Evoscan a viable data logger for the X yet? Or is it not worth it yet...?
Old Apr 30, 2009 | 08:19 AM
  #604
evo4mad's Avatar
Yes EvoScan works for EvoX try it out, the link is in post #1
Old Apr 30, 2009 | 09:13 AM
  #605
90GSX-03EVO's Avatar
Tried using v2.6b11 according to the instructions on page 1. I only register 2 samples per second at most, and usually I get one sample every 3 seconds. This is on an Evo 9 using an OpenPort 2.0 cable.
Old Apr 30, 2009 | 09:53 AM
  #606
evo4mad's Avatar
you must be doing something wrong, most people get >100 samples per second. Ensure you don't have any graphs open, and you don't have any gauges open, and you can check your settings in the logger menu, and you can check what items you have checked.
Old Apr 30, 2009 | 01:55 PM
  #607
dolphin888's Avatar
I have the same situation in one my laptop. It is software/hardware related, as OP 2.0 works perfect with other laptop...
I noticed that in device manager (on laptop which has low sampling), I can find unidentified comm port, which can't be uninstalled
Anyway OP 2.0 has worse compatibility comparing with OP 1.3, but I guess, it has to be this way, as OP 2.0 is more complex device
Old Apr 30, 2009 | 03:06 PM
  #608
I'm only logging:
- TPS
- RPM
- KnockSum
- InjPulseWidth
- TimingAdvance
- O2Sensor
- Battery
- AFRMAP
I never use the graphs or gauges. All settings have been verified. I bought this laptop exclusively for tuning / datalogging based on based on reviews (Asus EeePC with a 900 MHz Intel Celeron processor and 2 GB of RAM. I never could get EvoScan 2.5 to work with this computer using the OpenPort 1.3U cable. Flashing works great with both cables on this laptop.
I'm guessing I'll be told in the near future that I need to buy a different laptop.
Old Apr 30, 2009 | 03:13 PM
  #609
I'm only logging:
- TPS
- RPM
- KnockSum
- InjPulseWidth
- TimingAdvance
- O2Sensor
- Battery
- AFRMAP
I wonder if it is the 2.0 cable and/or settings
I've logged with my EeePC and 1.3 cable (I use it for logging at the track) and get great sample rate:
Old Apr 30, 2009 | 03:39 PM
  #610
Well with the 1.3U cable, EvoScan v2.5 would just engage and disengage over and over. With the 2.0 cable and v2.6b11, it engages at a horribly low sample rate.
Old Apr 30, 2009 | 03:47 PM
  #611
Yea I'm not doubting you.
It would be interesting to see more people's results from logging a 8/9 with a OP 2.0 cable.
Old Apr 30, 2009 | 06:14 PM
  #612
bbarnhill's Avatar
Any idea when the full version of 2.6 will be released with full X support?
Old May 4, 2009 | 03:27 AM
  #613
evo4mad's Avatar
next week, I'm just confirming some formulas and PIDs
Old May 4, 2009 | 06:11 AM
  #614
EvoDan2004's Avatar
just like every winter i go into hibernation. lol so i got to catch up with this stuff.
is there any bugs or issues with the ecuflash 1.41 or evoscan 2.6??? i want to down load the latest versions that are bug free or hassle free. right now i have 1.29 and evoscan 2.0
Old May 4, 2009 | 06:12 AM
  #615
rogue's Avatar
Nice! Great to hear!
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
