EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#768
I've got a question involving the fuel trims. Mine are still reading 0.1008. In another thread, someone told me I had to turn the immobilizer off using the periphery bits, but that didn't work. Is there anything else I'm missing? I've been searching for a couple of hours and came up with nothing, any help would be greatly appreciated.
#769
Evoscan is pissing me off. I have made 20 damn logs just fine, but it won't let me freaking access them through windows. Everytime I go into SavedDataLogs there isn't anything there but Sample logs. When I open EvoScan it says "Running Windows Vista Only Read Access - Folder permission updated Successfully" But it will let me view them in evoscan. What the hell is going, someone help me before I throw is laptop out the damn window.
Along with zero ability to update the data xml file and have new requests populate in evoscan.
See also,
I've been fooling with it for hours... and hours... and I'm about 2 clicks south of a full blown baby kicking rage. If I didn't have so much stuff I need on this laptop I would have already shot it to oblivion with a 12 gauge. The program itself WORKS. But I cannot seem to make it do what I NEED it to do outside of what is already there.
If you really want to get to your logs outside of evoscan, click one, hold ctrl, drag to an empty spot (while in evoscan / open) and it will copy the file. Now go through and delete the copies. You can then fetch them out of your recycle bin. Otherwise trying to move them, it says file path incorrect.
It also hangs on any kind of setup. You cannot remove / install the program fresh. So be wary. No matter what I do I cannot start over with it. It reinstalls the same way it just was when I removed it. I've tried deleting it, removing it with other programs... everything short of running the files through a shredding program.
And it still stays the same. I can't seem to fix it.
-EDIT Beta 16 works. owned...
#774
Do you have a JDM EvoX? Parts of beta 14-16 were created using my (JDM) car so I may be able to help.
I used to have that wideband problem too. It turned out to be the adapter causing the problem. My old adapter worked fine with other programs such as PCMScan, but on Evoscan, it would log for a few seconds, then stop. I bought a Keyspan adapter and all is fine now.
#776
What is your current logging rate? I'm getting around 110/sec on a slow EeePC.
2- my evo is USDM
3- im using that same adapter on an evo 8 and it works fine
#777
^^^ THIS!
See also,
See also,
#779
Hmm...I just tried beta 16 on an EVO X and the "USA" section doesn't work but the top section of tabs does work. Also, when I first loaded it, I noticed the baudrate was set to that of my EVO 8 and throttle was also stuck at 100. I bumped it up to 500000 and it read throttle with no problem.
