EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Aug 17, 2009 | 06:20 PM
  #961
Aman's Avatar
i download EvoScanv2.7Beta1 to see if it would solve aem wideband problem. but i still get same error. on hyper terminal the values are straight forward. nothing wrong their. mitsulogger works.
2009-08-17,07:31:01.79687,LogDataItems WDB AEM InputStream:15.2
15.2
15.2
152
,Input string was not in a correct format.,,
2009-08-17,20:16:42.26562,LogDataItems WDB AEM InputStream:.6
14.6
14.6
14.1
1.1
2009-08-17,20:17:34.04687,LogDataItems WDB AEM InputStream:
15.4
!5.4
2009-08-17,20:17:57.14062,LogDataItems WDB AEM InputStream:
14.5
!4.5
2009-08-17,20:18:12.26562,LogDataItems WDB AEM InputStream:
14.7
14.7
14.7
14&7
14,Input string was not in a correct format.,,
2009-08-17,20:20:02.85937,LogDataItems WDB AEM InputStream:12.4
12&4
12,Input string was not in a correct format.,,
2009-08-17,20:44:47.26562,LogDataItems WDB AEM InputStream:18.3
!8.3
18,Input string was not in a correct format.,,
2009-08-17,20:45:03.40625,LogDataItems WDB AEM InputStream:15.0
15.0
14.1
14.1
14.1,Input string was not in a correct format.,,
2009-08-17,20:46:58.96875,LogDataItems WDB AEM InputStream:14.9
14.9
14.9
14.7
14.7,Input string was not in a correct format.,,
Old Aug 17, 2009 | 06:33 PM
  #962
bambooi's Avatar
15.2
15.2
152
14.6
14.6
14.1
1.1
15.4
!5.4
14.5
!4.5
14.7
14.7
14.7
14&7
12&4
!8.3
15.0
14.1
14.1
14.9
14.9
14.7
So are you only having problems logging the uego with the touchscreen unit? Do you have problems with a laptop? Do you use a serial to USB cable?
Old Aug 17, 2009 | 06:46 PM
  #963
Aman's Avatar
yeah this is with the car pc... i am using serial port.. pin 2 and pin 5
Old Aug 17, 2009 | 07:16 PM
  #964
SoCalRedLine's Avatar
Hey hamish,
is there a way to save the date/time format on the gps logger? My unit keeps defaulting to 12:00pm Jan, 2003.
Old Aug 17, 2009 | 08:53 PM
  #965
xbox4414's Avatar
Beta1 fixed the AEM issue I was having. I'm running a laptop with Vista SP1 with a Mode23 X.
Old Aug 18, 2009 | 12:18 AM
  #966
infini_IV's Avatar
Originally Posted by evo4mad
It appears to only work with Evo4/5/6 for AYC, I need to find someone local with an Evo9 to try it on any voluenteers in NZ?
would an evo 7 suffice? id be willing to help if you could aslo help me get my evoscan/cable to comunicate with the ayc/acd system
Old Aug 18, 2009 | 03:30 AM
  #967
leecavturbo's Avatar
Originally Posted by SoCalRedLine
Hey hamish,
yes make sure its charged up and the bottom switch remains on.
then under option set date and time
but if you have to turn the switch off then the date is lost
Old Aug 18, 2009 | 06:55 PM
  #968
evo4mad's Avatar
I re wrote the AEM logger code from scratch, and tested it on an AEM with EvoX mode 23 and OpenPort2.0
EvoScanv2.7Beta2
Give it a try out now... The reason it changed from v2.5 to v2.6 is because I had to support Vista64bit users as well, so now that I have rewritten it, please check it out, and give me as much feedback as you can. cheers, Hamish.
Old Aug 19, 2009 | 11:47 AM
  #969
evo4mad's Avatar
xbox4414, can you please check the v2.7 beta2 (see post above), see if its still ok for you, since I rewrote the AEM code.
Aman: also try Windows version of EvoScan v2.7 beta2 (see post above), but looking at your logs: you AEM device is not wired well enough. hundreds of your AEM readings are corrupt "14&7" <-- that looks like a loose ground wire or something, do you see those sorts of characters in Terminal too? either way the new version will be better because it picks up the first AEM values coming down the line now.
The new version is very responsive when I compared it to the AEM display device now, its great.
Old Aug 19, 2009 | 11:53 AM
  #970
GST Motorsports's Avatar
Hamish,
Could you check your support tickets please? I lost email from a server crash so no longer have my serial # and I put in a support ticket last week...
Thanks!
Old Aug 19, 2009 | 12:36 PM
  #971
evo4mad's Avatar
Originally Posted by GST Motorsports
Hamish,
Thanks!
Yeah I'm away today, otherwise I clear them each day. I'll get back to you.
Old Aug 19, 2009 | 03:30 PM
  #972
bluexgyr's Avatar
I have logged using Mode23 2008 JDM EVOX (Aus spec car) using 2.6 and find my RPM log samples have repetative readings? Any ideas.
Thanks.
Old Aug 19, 2009 | 08:17 PM
  #973
Aman's Avatar
yes i do see different char in terminal too.. ground are good bolted right to chassis.
i tested EvoScan v2.7 beta2 it log fine for few seconds then it slow down then stop freezes up and it will stop and will try to reconnect then them same thing again . only when logging Aem but everything else works... no problem their..
with the engine not running aem logging work fine. engine running it doesn't. is it possible that aem controller is messed up
Old Aug 19, 2009 | 11:43 PM
  #974
xbox4414's Avatar
Hamish, I have not gotten a chance to check beta2. Beta1 was running fine for me. I'll check beta2 tomorrow.
-Ray
Old Aug 19, 2009 | 11:47 PM
  #975
Ruthless.'s Avatar
HOLY ****!!! THIS I WANT!
subscribed
Quick Reply: EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
