EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#978
Hamish it seems you now have your volunteer in NZ - I'm sure a lot of 7/8/9 owners will be very pleased to both log ACD/AYC datas and have the possibility to DIY bleed their ACD and AYC without paying $$$$ to a dealer
I it helps I also volunteer to test / take logs,....
Infini_IV , you can start to make sure your 1.3U cable is prepared fot ACD logging see instruction on Limitless homepage in the Tips And Tricks section
#982
can someone explain to me why i dont get the promised email updates and new versions of evoscan.?
I am still using v2.5 that i paid for and downloaded in march/april. I have never recieved a single email since my purchase.
I am also yet to recieve a resonce to a support ticket that i opened back on the 27th april...
Whats going on!
Whats going on!
#986
hammish,
can I substitute the provided gps nav adapter cable with a usb hub?
thus feeding the hub, via the cig power plug, a wide band usb and the ecu usb, with a usb (to the smaller plug adapter) cable into the gpsnav unit?
(just trying to reduce the rats nest on the dash)
#989
yeah you kinda have the right idea, but what about the power? you need to power the gps somehow, if you plug it to the usb hub then you have no power for the gps.
best option, you can buy some sort of mini-usb extension cable for the gps unit into the Y cable.
hammish,
