EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#97
Will the touchscreen device have built in storage for installing EcuFlash and Evoscan or will this have to be stored on the SDHC card? Will the device accept cards higher than 1Gb? Is this a windows device?
#98
well! I'm using the latest beta to log and helped fine tune my car for the last few days and look like all the functions and log data that I'm using are working good. The Zeitronix boost, egt, wideband data areg great. The map-tracer is much more useful now with some new tweaks.
I wonder if the fuel trims high/mid/low column values are correct?
#99
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Hi Hamish,
Can you check NaN when trying to draw those Dundas charts?
In case of fuel consumption with metric units, the exception is kind of annoying
and one has to kill the process to get rid of it.
I was missing IPW in fuel consumption formula in case of metric calculation. I do not know if that was deleted by me by mistake or it was with installation, please check.
#105
The fix for the missing LC-1 serial data is making it very difficult to read the logs. Instead of leaving blanks it is inserting 14, so the WOT logs have values..11.2 14 11.2 14 which is making the graphs zig zag between the real value and the inserted 14. How else can this problem be addressed?
