EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
#1396
I have win7 and had the edit issue and I went into the virtual folder under my user name and removed the evoscan folder (moved to desktop temporarily)....I wanted to see if the program still worked and it did. I can edit the xml now without issue and its still in my programs folder.
Every feature seems to work fine......
#1397
Hello,
Can someone help with Evoscan 2.6 ? My logs are mad.. When I try open it in the evoscan the AFR scale is between 0-100 scale ?! I can not view my log like in the picture :
Here is picture about my log :
and doesnt appear the small note on point to see the exact afr boost rpm load knock ?!
Anyway How can I open my log in Excel like that ?
I tried it but it was only numbers and text no graph or like that.
Plese help, thank you !
#1400
Having a weird issue with v2.7. Anytime i try to add anything or edit .xml in EvoScan, it throws error "Sorry, errors were found in orginal data.xml, you cannot save the xml file until these errors are corrected". But, i've never edited the .xml, so this is the original .xml. Also, when i try editing the .xml myself and replace the original .xml, the new .xml will not show up in EvoScan(does not reflect the changes to data item list), even though the data.xml has the new settings in it.
It also say permission read only at the bottom of the program, does this mean anything?
All i want to do it add the Omni 4 bar into the data.xml.
Thanks fellas!
Thanks fellas!
I just ordered/payed for the final V2.7 version, so hopefully that problem won't be carried over.
#1402
Silver Sponsor
yeah seems like vista and win7 really hates software with config files in the program files folder because its soo locked down, I think win7 and vista wants us to use the c:\users\ folder for all user edited information. I guess v2.8 of evoscan will have to comply thoroughly. In the meantime, just give full control permissions to evoscan installed to folder and you won't have a problem, as instructed on my website. The bottom status bar of evoscan when you start up if it says "read only" then you may have a problem and should set full control permissions to the folder yourself. it will say read/write in the evoscan status bar when its installed and working correctly.
#1403
Silver Sponsor
#1404
It is my log :
http://img214.imageshack.us/img214/6392/83782767.jpg
that is all what can I see.
#1408
Small problem here with Evoscan.
I recently purchased Evoscan 2.7 Beta final and have a problem logging IDC.
Amongst others, I have IDC and IPW checked for logging.
IPW logs fine but IDC just shows zero's, which is odd as IDC is an calcualtion based on the IPW data, and you would expect to see values for IDC if IPW was logging fine.
My Evo8 uses the latest 96530706 and I have gone as far as flashing the stock std rom back onto the car but it made no difference, IDC still shows as 0 while logging.
I logged a support ticket with Hamish but have not received any solutions as yet.
Anyone have any idea/suggestions of what might be wrong?
Thx
Thx
#1410
