Timing & Fuel maps: Load auto-rescaling (XLS file)
Old Apr 10, 2009 | 09:23 AM
TurboTylerIX's Avatar
Nice work, I really like this spreadsheet. You really helped me out! Thanks!
Old Apr 10, 2009 | 10:27 AM
sti.this's Avatar
I havent started tuning hard with mine yet this spring. But Ive used your tool to rescale from some logs a while back and it seems to work pretty good. Upping the boost a little afer my new dv comes in, Ill surely be testing it then, and hopefully re-scaling again
Thanks.
Old May 8, 2009 | 12:25 PM
fostytou's Avatar
EvoM Community Team
Keep other tables in mind other than what are listed here when you re-scale:
https://www.evolutionm.net/forums/7038290-post28.html
Also, pay attention to how things are being re-scaled... remember this sheet is quicker than you, but not as smart as you. For instance, it may subtract more timing than you want in edge cells, and it won't see things in the EGR advance tables where 10 and 20 load are the same value, 30 and 40 load are a much higher/lower different value, but you are having it try to interpolate between 10 and 40 load. It can't smooth the center of that as well, because, well... it isn't smooth to start with!
Old May 8, 2009 | 01:14 PM
Vigman's Avatar
I am happy to see that this XLS finally helps some of you!
Remember it's only an approach file to start with something logic but you will need to adjust cells by yourself... As fostytou said, "this sheet is quicker than you, but not as smart as you"
Anyway, if some of you wants to help with concrete feedback, it time to do it cause I am about to work and publish a new version with new features soon!
Cheers,
C>
Old Jun 26, 2009 | 07:41 PM
stuntkiwi's Avatar
Awesome thanks for this!
I used the used the ignition tables in the "Original maps" sheet to do my fuel map scaling. Using the fuel tables seemed to scale the top left corner closer on both axis.. ignition came out looking great. Thanks again.
Old Oct 6, 2009 | 09:40 PM
fostytou's Avatar
EvoM Community Team
Bumping this, I'm not sure what needs to be done to make it work with the new cells in the big maps, but I'm guessing not much. I'll see if I can dig in tomorrow.
It might be good to do this to the big map before release so values are at least consistent.
Old Oct 6, 2009 | 09:55 PM
tephra's Avatar
oh wow i didn't even know about this...
i even made my own crappy one.. (For the bigmap stuff)
- rename to .xlsx
File Type: doc
Old Oct 6, 2009 | 10:26 PM
fostytou's Avatar
EvoM Community Team
OK, I actually went ahead and started on it. It scaled well to the right for load, but didn't do anything for RPM. Need more time in the day!
If someone gets RPM working please send it to me so I can host...
http://thefrost.net/randomfiles/tuni...P_Fostytou.xls
Old Oct 6, 2009 | 10:32 PM
fostytou's Avatar
EvoM Community Team
- rename to .xlsx
Here is a hosted version with the proper extension:
http://thefrost.net/randomfiles/tuni...or.Tephra.xlsx
Please note that I changed the axes in the big map because there wasn't any 0 column (removed 5250 and added 0). I know that it would interpret 500 the same as 0, but I figured there was a reason it was there.
Old Oct 6, 2009 | 11:09 PM
tephra's Avatar
nah I've buggered off 0 load/rpm from the V7 release...
it should interpolate down (or up as the case maybe)...
Old Oct 10, 2009 | 11:01 AM
Vigman's Avatar
Hi guys!
I am busy this time but let me know if you want me to have a look on this!
I want the big map too!!!
Good luck and congrats for the new V7 ;-) I'll wait for 88590015, and please do something on 7.1 for people who wants to logs EGT on ECU with Mr Fred trick and this small circuit...
I will publish some feed when I get some time to finish this...
Cheers,
C>
Old Oct 18, 2009 | 03:21 PM
fostytou's Avatar
EvoM Community Team
Originally Posted by Vigman
Hi guys!
Cheers,
C>
Hi Vigman!
I started to re-do your sheet with a new tab for RPM here:
I'm still having trouble with the equations. I understand each function, but trying to parse it all out has been difficult. If you could update the sheet now that v7 is out for our rom that would be very helpful.
Thanks!
link to v7 download https://www.evolutionm.net/forums/7624459-post430.html
Old Nov 2, 2009 | 05:55 PM
Vigman's Avatar
I guys,
Sorry for the delay but I was too busy to do it last weeks...
Here is a beta version for rescaling your maps to Tephra V7 bigmaps....
I did not try V7 already so I can't tell you how precise it is but it should be safe...
Hope it will helps!
Cheers,
C>
Old Nov 2, 2009 | 06:12 PM
recompile's Avatar
I've added this to SVN (user/pass = evom/evom) https://rallyevo.com:8443/svn/evom/spreadsheets
Old Dec 25, 2010 | 07:48 AM
Vigman's Avatar
The user/pwd is not working anymore. Can you please update info?
richardjh
Jul 28, 2017 03:49 PM
Vigman
16
Jun 16, 2010 12:54 AM
Stradag
Jan 3, 2010 04:26 PM
C130flyer
Sep 22, 2009 11:21 AM
Noogles
May 12, 2006 06:04 PM
Quick Reply: Timing & Fuel maps: Load auto-rescaling (XLS file)
