Tuning with the new Magnus
NEW CAST MAGNUS CAST INTAKE MANIFOLD
Okay this thing basically tuned itself. Well not really but this manifold lost no power, picked up torque and power under the curve and total as well.
Here is the dynosheet:
This car has already been tuned previously on E85, stock cams/MAF/ECU, no piggybacks, ETS 57 trim and 3" TBE, ETS pipes, etc. I am thinking that on a MIVEC car it would be even better. I need to look for all the old logs that I have previously but the boost has been the same both time 28 falling to 25. It picked up a little noise prior to full throttle, but basically it was just a little scattered spool noise. As you can see this one let me run max MBT timing on this vehicle (fuel always helps) but it picked up 4hp with 1* but we werent gonna push it any harder at the owners request. I think this on the motor he is building and another 4-5psi on stock cams will make 500whp and with cams should just go nuts.
Here are the logs:
Here are the logs:
In talking with the ER boys the torque can still be better because they were part throttling through part of the pull in case this wanted to surge. I am definitely impressed with the power on a 57 trim and cant wait to see what it will do with a Red or 35.
TTP Engineering
May 17, 2010 07:20 PM
TTP Engineering
45
Dec 1, 2009 12:32 PM
Lucas English
26
Aug 11, 2009 11:43 AM
maperformance
20
Aug 6, 2009 01:29 PM
TTP Engineering
22
Aug 3, 2009 09:36 AM
