e85 fpgreen 1 walbro...
#32
We've had a FPgreen to 420whp on our mustang dyno (bit more than you are making on a dynojet depending on what cool kid conversion you use) and the single walboro was still fine and RC1000cc injectors where at a little over 90% IDC via evoscan.
#33
Bryan,
I am wondering on that Green you mention, your dyno to a DJ would make that 480-490? Did you still have fuel control at the 90% or was it going lean on its own? I am sure that we deal with alot of clogged filter cars around here because of the recent E85 revolution but thats still in the range we see where the pump maxes out with the 1000's.
I have pushed 1200s a little harder and managed slightly lower IDCs at the same power level (85% at 475whp) with one pump on E85 but even the math shows the pump is about done.
1200cc=1.2L, 1.2 * 60 * 4=288lph demand at 100% IDC
#34
Bryan,
The couple times I have run out of single pump on our dyno, it has been around 460-470whp and the IDC's have been in the 90's as well and I have lost control of fuel.
