Decel Fuel Cut and Cooling Fan Maps for 94170015?
Can anyone resolve the Decel Fuel Cut Delay and Cooling Fan maps for 94170015?
The Decel Fuel Cut Delay code for the older 94170008 ROM are as follows (see below), but those for the later ROM (94170015) have yet to be disassembled.
I don't know if any of the cooling fan tables have been resolved for the EVO 8 (anyone?).
Glad to make a donation to the cause if it helps.
<table name="Decel Fuel Cut Delay - Neutral A/C Off" category="Fuel" address="42bc" type="2D" level="2" scaling="uint8">
<table name="Load" address="650a" type="Y Axis" elements="7" scaling="Load"/>
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C Off" category="Fuel" address="42ca" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - Neutral A/C On" category="Fuel" address="42d8" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C On" category="Fuel" address="42e6" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Ignition Retard" category="Fuel" address="4300" type="2D" level="2" scaling="Timing">
<table name="Engine Speed" address="61da" type="Y Axis" elements="10" scaling="RPM"/>
</table>
</table>
</table>
</table>
</table>
</table>
