Can't log AEM WB in Vista (Evoscan)
I'm close to smashing my new laptop to bits. Evoscan logs just fine but when I try to log the AEM Wideband through a serial cable it will not work. I set the com port to 3 in device manager and then set it to three in Evoscan. At one point it actually read for half a second (incredibly annoying) before cutting out.
The message I get now with version Evoscan version 2.6 is "wideband port is already in use, close the other program or choose a corrrect com port from the wideband menu"
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID: E4C7
Info: Connection successful...
Error: Unable to open COM2
The system cannot find the file specified
Info: Datalogger Ended.
I have used this setup on my old xp laptop without a problem. Has anyone gotten around this problem? Thanks.
Info: ECU ID: E4C7
Try another comport. You may just have a conflict.
Or try slowing the port speed down.
Also you are using a beta version of Evoscan. Try an older version.
tboboy
Apr 29, 2010 11:58 PM
