EvoScan 2.5 and VISTA..HELP...
Yeah that is the problem I have now as well........it says link engaged and the square goes green as it should be logging but no data to be found. I even loaded the 2.6 beta and have the same issues.....
Try to download the latest 2.6beta version, that should fix your problem. Also try setting it to run as Administrator.
Im in the same boat on 64-bit vista.
I don't think the beta 7 version has it fixed yet......There is a note on the main page from Hamish that says it is being worked on so I don't believe it was implemented. Hopefully the next release it will be resolved.
I have the latest beta version working on my laptop with Vista 64bit. I right clicked and set it to run as an administrator and I haven't had a problem with it yet.
I have the same problem with wideband although 2.3 and of course earlier versions work fine.
