ecu flash jacked up!!
Ok so last week i was adding 5.1patch to an 06 evo9 rom. My laptop crashed, it was late, so i went to sleep. Didnt get back to it till today. I never finished on that xml but it was open when the comp crashed. Tried to open the rom today thinking that when it last crashed the incompleted work was never saved, so it should load up fine right??
Negative!
"Parse error at line 329, column 29:
unexpected character"
all values in all maps arent there, the high an low octane maps are greyed out and the whole timing section is greyed out
other roms i have loaded worked fine...
So i uninstalled ecuflash 1.35 an reinstalled 1.4
Again, Negative!
its like ecuflashes blue screen of death. Sheeeit!!
other roms i have loaded have scrambled values all over...
So i went further dl'd the stock 9 rom(88590015) from active matrix. Uninstalled/reboot/Reinstalled 1.4, put the original xml an evo 9 base from v1.3 Since the ones from 1.4 didnt work. All still with the same errors. i dont get why is just this rom an xml fubar? An all the others are scrambled. This is like v1.29- days. I thought it was maybe the endians but that doesnt make sense for the utter destruction to the 88590015 rom and xml.
I have v1.3 backed up on an external. If i run the program off there i get assulted by the same error. The dialog box to the right shows nearly all the xmls to be invalid?
Any ideas?
Negative!
Again, Negative!
Any ideas?
whatever, the file is XML so its just plain text.
you can use notepad if you like, but obviously you will need to count to 329 as notepad doesn't display linenumbers (AFAIK)
edit - In Notepad you can "JUMP - CTRL-G" to a line number... just use notepad then
another thing is isnt it supposed to read the evo 7-9 base as well as these?
[19:18:10.875] 253 ROM metadata models scanned.
[19:18:10.875] checksum module "subarudbw" loaded.
[19:18:10.876] flashing tool "wrx02" loaded.
[19:18:10.877] flashing tool "wrx04" loaded.
[19:18:10.877] flashing tool "sti04" loaded.
[19:18:10.879] flashing tool "sti05" loaded.
[19:18:10.879] flashing tool "mitsukernel"
Ah yeah the rom id is blank
<rom>
<romid>
<xmlid>88590015</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>88590015</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO9</submodel>
<transmission>Manual</transmission>
<year>2006</year>
<flashmethod>mitsukernelocp</flashmethod>
<memmodel>SH7055</memmodel>
</romid>
<include>evo9base</include>
<rom>
<romid>
<year>2006</year>
</romid>
ok - just copy/paste the last 50 lines from that file in here...
ps - this is what ecuflash *should* look like when you load+open a rom
Code:
[14:50:40.671] Version 1.40.2178 [14:50:40.687] 19 memory models read. [14:50:40.703] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata [14:50:45.500] 325 ROM metadata models scanned. [14:50:45.500] checksum module "subarudbw" loaded. [14:50:45.500] flashing tool "wrx02" loaded. [14:50:45.500] flashing tool "wrx04" loaded. [14:50:45.500] flashing tool "sti04" loaded. [14:50:45.500] flashing tool "sti05" loaded. [14:50:45.500] flashing tool "mitsukernel" loaded. [14:50:45.500] flashing tool "mitsukernelocp" loaded. [14:50:45.500] flashing tool "shbootmode" loaded. [14:50:45.578] flashing tool "shaudmode" loaded. [14:50:45.578] flashing tool "subarucan" loaded. [14:50:47.984] 88580013 (93 tables) inheriting evo9base_20081101 (136 tables) [14:50:48.000] 88580614 (56 tables) inheriting 88580013 (129 tables) [14:50:48.062] 524288 byte image read.
<table name="Knock Sensor Filter Map 5" address="4651">
<table name="TAR" address="7356"/>
<table name="RPM" address="7316"/>
</table>
<table name="Knock Sensor Filter Map 6" address="42a5">
</table>
<table name="Knock Sensor Filter Map 7" address="495b">
</table>
<table name="Knock Sensor Filter Map 8" address="4a17">
<table name="TAR" address="7356" elements="16"/>
</table>
<table name="Knock Sensor Filter Map 9" address="4ad3">
</table>
<table name="Knock Sensor Filter Map 10" address="4b8f">
</table>
<table name="Knock Sensor Filter Map 11" address="4c4b">
</table>
<table name="Knock Sensor Filter Map 12" address="4d07">
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Speed Limit" address="118e">
<table name="Condition"/>
</table>
</rom>
ECU ID and CASE ID are blank when i open the rom info box. How do i get my ecuflash to load in that fashion? I guess ill reinstall again
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</rom>
