BCS for ECU controlled boost
Not to sound like a newbie but I've avoided using the BCS like the plague but with the advancements going on with using it, I may go this route.
What is the readable boost limit using the BCS such as the GM?
-E
-E
https://www.evolutionm.net/forums/ec...ting-data.html
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=56973466
I wonder if this is the same as the Perrin unit. Very inexpensive. I just bought some 4 ways of these for a test stand at work. Looks very similar, has the leads coming out of the coil. Can't beat $26 and easy to get.
EvoM Community Team
http://www.pegasusautoracing.com/pro...asp?RecID=5706
(other oem images here: http://www.whiteproducts.net/connectors.shtml )
But from the images of part numbers that I can see it is actually the 2-prong metripack 280 seen here:
http://www.whiteproducts.net/sealed280.shtml
Can anyone who has one confirm? The difference between the two connectors is one is a circular style with seperation and the other (metripack) is a multiple inner square push-down style with no separation.
Thanks guys!
And yes, the gmpartsdirect is around $48 shipped. It used to be $17 from rock auto . I've been meaning to call a GM Dealer and see if there is a newer part,but I haven't had the time.
EvoM Community Team
Also, this page on the wiki might help the guys who have other suggestions. Feel free to contribute any info we find to the wiki:
http://evoecu.logic.net/wiki/3_Port_Boost_Control
Note, there is a link there also that shows the AC connector that can be cut for PNP
EvoM Community Team
Speaking on the pig-tails... I know I've seen posts that say it is the standard weatherpak connector that you can get for $.59c here:
Thanks guys!
Thanks guys!
