94170008 to 94170015
ok well i tryed this on my car and i check everything the immoblizer code and everything is good and the car will not start... has anyone else had this problem?
I swapped a locals car from 9417008 to 94170015 and I had 0 issues, car fired.... He wanted to run the tephra rom so I got it all setup for him, copied the tables over from the tune I did on it and its been a few months now and he has not said a word to me so I guess all is well...
I'd say double and triple check you didn't miss something........
No it wasn't a stock tune, it was a self tune.. The Map looked real good, the only table that showed up crazy was the Boost Limit table. Maybe I had a corrupted ROM..
I reviewed the maps sent to me and it was the auto-valet on fresh ignition. It was activated and the rev limit was 114 rpms which caused the car to not start.
easy mistake but that should fix the problem, i sent you your map back with auto-valet disabled and I bumped your valet rpms up just to make sure it will start.
Hope it works.....
- Trav
Hope it works.....
- Trav
