Boost Issue
Boost Issue
Seem like I have an issue and wondering if I am overlooking something. No matter what my wgc duty is after 7600 it goes to 100%. I am within target psi until the 100% happens. The wastegate solenoid activiation rpm table deactivate on/off are both set to 9000. In the TBEC I have no upward correction. When doing a log with evoscan the wga duty cycle correction shows 0. I know if the WGSA rpm is set below your rev limit that this happens but it sets beyond reach. My rom ID is 94170015, is this a VIII thing that has no fix?
Thanks
Brandon
Thanks
Brandon
thanks bryan for helping
Just checked, 1A68 is correct and what you should be using.
With 1A68 it should look like this in a stock rom:
Reactivate On 2250
Reactivate Off 2156
Deactivate On 7500
Deactivate Off 7500
To increase the RPM on which it automagically shoots to 100% WGDC just up both the Deactivate On/Off values
Reactivate On 2250
Reactivate Off 2156
Deactivate On 7500
Deactivate Off 7500
LaXGSR
Jun 8, 2009 01:50 PM
spdracerut
Mar 31, 2007 04:26 PM
