TephraMOD V6 - testing!
Old Jul 6, 2009, 02:09 PM
  #1096
phenem's Avatar
Originally Posted by scheides
Not sure if this is V7t6 related, but I have been getting an 'idle control system' CEL that will simply not go away. Car idles just fine, all systems appear to be normal.
If you use my ROM above it will be disabled for you, if not set Periphery 2 (FCA) Bit 8 to 0 and that will dsiable that CEL and you should not get it anymore.
Old Jul 6, 2009, 03:22 PM
  #1097
gear head's Avatar
Try adjusting the BISS to get rid of it...
Adj. BISS under SAS mode in evoscan to get the stepper counts lower(somewhere in the 20's usually works good). This has worked for me on every car I've put the EDM ROM in, I haven't tried the v7 yet though.
Old Jul 6, 2009, 06:58 PM
  #1098
EvoM Moderator
scheides's Avatar
Originally Posted by TTP Engineering
P0507? Disable the idle system check in the periphery bits.
Bingo! Thanks TTP, good call!
Old Jul 6, 2009, 07:07 PM
  #1099
TTP Engineering's Avatar
Been there done that.
Old Jul 9, 2009, 09:56 AM
  #1100
laramie_05MR's Avatar
Donation sent.
Old Jul 10, 2009, 12:32 PM
  #1101
kaj
kaj's Avatar
so. is all this info updated in the first post of the thread, or do i need to sort through all 75pgs? i'm just getting on board and won't wanna miss anything.
TIA.
Old Jul 10, 2009, 12:34 PM
  #1102
EvoM Community Team
fostytou's Avatar
Originally Posted by Darwinn
Ideas how to maybe improve nlts
1) gear dependent rpm drop
2) in x time\gear, nlts can be activated only one time. like a limiter\timer. personally i can hold my foot on clutch pedal after shifting for some time, ecu activates nlts second time and car bogs
1.The RPM drop should be less than your RPM actually drops. You should not have the clutch out that long anyway. I suggested a much more complicated RPM drop/ downshift limiter a while back... but it is much more complicated and adds other features as well.
2. Don't rest your foot on the clutch. It is a bad habit with or without NLTS.
Old Jul 10, 2009, 01:02 PM
  #1103
Asmodeus6's Avatar
TIA.
There are updates and info throughout. There is not a final release version yet for any of it.
V6 basically merged into v7 as it went along with new features being added. None of the code is finalized for everything. But there are a lot of stable individual roms strewn through it.
96530706 is on V7.6 and appears to be working.
And both V6 roms posted on the front page are not as far along with features, but work, I believe.
Old Jul 11, 2009, 07:39 PM
  #1104
GiGas's Avatar
Will any one be able to make a list of known "latest vertion" for eatch rom.
And even better place them in one post ( should be the first post in this tread )
Think I am not the only one getting confused reading about issue in a V7.6 in a trad about testing V6 not knowing that we talk about issue in a Rom that is not mentiond in post1.
Old Jul 11, 2009, 08:18 PM
  #1105
GiGas's Avatar
Originally Posted by tephra
thanks!
ok so what I will do is use this thread as a rom testing thread, and once romid's are tested and working I will post them to the "real" v6 thread... that should keep questions in the real thread to a minimum...
Am I missing somthing her? cant finde the "real" v6 tread.
Old Jul 11, 2009, 11:09 PM
  #1106
Asmodeus6's Avatar
Originally Posted by GiGas
Am I missing something here? cant find the "real" v6 tread.
Yes. Here's the deal... this stuff isn't formally 'done' yet.
When it's done, it will be posted in neat, 1st page format... just like all the other ones were. You can either dig through 75 pages for the information and what is available now. Or, wait.
However, the rom you would use is on page 1.
It's still in V6 format. It has not, and will not be updated to V7 until the V7 code is finalized so Tephra can write the individual roms with proven and tested code.
As it sits 96530706 is the rom in V7 BETA format. And appears to be stable and working. Until Tephra is happy it has been tested thoroughly - or has time to confirm everything is working correctly. None of the other roms will be updated.
V6 TESTING became V7 TESTING as more features were added midway through. Neither were ever FORMALLY COMPLETED, OR RELEASED. This is the only V6 thread. Again, you can either read it, or WAIT PATIENTLY.
Old Jul 11, 2009, 11:48 PM
  #1107
kaj
kaj's Avatar
haha. i'm lost too. i don't know what to use.. what to change, etc. i guess i'll just wait it out. LOL
Old Jul 12, 2009, 03:01 AM
  #1108
tephra's Avatar
right on Dustin...
sorry guys I will have V7 out officially sometime this week.
been busy with life hehe
Old Jul 12, 2009, 03:42 AM
  #1109
GiGas's Avatar
Hello friends, I can not see reason to denigrate me here! My suggestions coming because I spend many nights to read the forums here.
Tephra modifications found in many vertions to various ROM's V5.10, v5.5 V5.7 Moreover V6 and V7 that are under test. An updated reference list of all Tephra Rom's is not a bad idea?
'm Sorry to be misunderstood here
Old Jul 12, 2009, 07:46 AM
  #1110
Are the 2005's the only model the 96530706 works on? Haven't been able to get it working on any other prior year.
Quick Reply: TephraMOD V6 - testing!
