TephraMOD V6 - testing!
Old Jul 18, 2009, 01:46 PM
  #1126
Asmodeus6's Avatar
Yes, they are. But you have to use the new 3D tables.
You will have to rescale them to psi, and incorporate all the other stuff. But you only use the new tables. (And boost error correction, boost adder, and boost limit tables)
You can pick up the rom / xml that phenem posted where all of this has already been done for you.
It's download #2. It works.
Old Jul 18, 2009, 11:27 PM
  #1127
roguck's Avatar
thanks but it wasn't those bits I was thinking of it was just the resolution bits that relate to the WGDC correction with the load based boost.
here's the link;
https://www.evolutionm.net/forums/ec...trol-mods.html
the main interest is changing the WGDCC.
Richard
Old Jul 19, 2009, 06:02 AM
  #1128
phenem's Avatar
here's the link;
Richard
The application of mrfred's psi based boost control is exactly the same as any other ROM. I applied this MOD with the ROM's I posted. So the WGDCC acts exactly as it would with an unmodified ROM with just the boost MOD done. However where Tephra adds more to it is within the gear based WGDC control. You must use those maps when tuning the WGDC with his ROM. Once implemented correctly it is working like a charm.
Old Jul 20, 2009, 06:52 AM
  #1129
LeXcite's Avatar
hi all, is there any xml for 97470001 ?
I have an Evo 8 MR RS 2004, is there any way to switch to any other RomId?
EcuFlah can't show any tables, cos no xml files for 97470001
Old Jul 20, 2009, 07:22 AM
  #1130
LeXcite's Avatar
Just have founded 97470001.xml, converted Endians ... Workin great.
Want to apply Tephra patches, any chances, or i need to change my Rom?
Old Jul 20, 2009, 07:44 AM
  #1131
LeXcite's Avatar
Old Jul 20, 2009, 07:51 AM
  #1132
denver's Avatar
The way i understand it, 96530706 works on all evo 8s.
There is a download in this thread with V7 for this rom id, maybe page 7 or so.
Edit: It is actually post #651
you have to change your immobilizer code or disable the immobilizer
Old Jul 20, 2009, 09:54 AM
  #1133
LeXcite's Avatar
Thanks denver, have now 97470001 Tuned, what i must to do with new rom to stay in tune ?
Old Jul 20, 2009, 09:57 AM
  #1134
LeXcite's Avatar
And one question more :
My car is EDM, is it ok to flash USDM rom (96530706-v7t6-mods-phenem.zip)
Old Jul 20, 2009, 10:27 AM
  #1135
Asmodeus6's Avatar
96530706 IS NOT a USDM rom. So if anything WE should be more worried about it than you. But it works.
Old Jul 20, 2009, 10:47 AM
  #1136
fixem2's Avatar
I believe it is an EDM or AUDM ROM
Old Jul 20, 2009, 10:48 AM
  #1137
MR Turco's Avatar
Hows the V7 testing going? Any idea on a general availability date?
Old Jul 20, 2009, 11:10 AM
  #1138
SoCal Rally's Avatar
In keeping with the newish ROM ID versioning scheme, and since V6 was skipped & those changes rolled into V7, when the ROMs are officially released will they be released as e.g. 88590715?
Old Jul 20, 2009, 11:14 AM
  #1139
denver's Avatar
I do not know the mods etc on your car, but basiclly you want to copy over all your tuned tables into the new V7 rom, either in primary or alt, depending on what you are doing with the car.....
Old Jul 20, 2009, 01:58 PM
  #1140
LeXcite's Avatar
Just basic bolt ons ... Injen IC Pipes+Intake, TBE, EBC. So does it mean that my tune is simple correction to fuel and timing? And all i have to di is copy Fuel and Timing tables to new Rom ?
Quick Reply: TephraMOD V6 - testing!
