TephraMOD V6 - testing!
Old Aug 5, 2009, 10:24 AM
  #1231
project_skyline's Avatar
Originally Posted by mrfred
I'll have prepatched v7 SD 88590015 and 94170015 ROMs made up shortly after tephra releases his final v7 ROM.
94170015 roms?
Didn't that rom get dropped?
Old Aug 5, 2009, 10:33 AM
  #1232
MR Turco's Avatar
Originally Posted by project_skyline
94170015 roms?
I really hope that rom doesn't get dropped. I still am not confident with 96530006
Old Aug 5, 2009, 11:19 AM
  #1233
Jack_of_Trades's Avatar
+1 for now. I'd like to see more time with 96530006 being used with other ROM ID conversions before we write it off completely. Getting there though!
Old Aug 5, 2009, 12:15 PM
  #1234
MR Turco's Avatar
What is the ADC0F bug? is this going to cause issues on the IXs with a map switch harness?
Tephra, never saw an answer to this.
Old Aug 5, 2009, 12:25 PM
  #1235
travman's Avatar
I think its only if you have the switch time to 0ms.....
Old Aug 5, 2009, 04:18 PM
  #1236
0xDEAD's Avatar
Much appreciated. IAT's are needed data for me.
Old Aug 5, 2009, 04:51 PM
  #1237
When was the last update for 94170015 as far as tephra mods go?
Old Aug 5, 2009, 05:51 PM
  #1238
travman's Avatar
You just add the stand alone patch back in like you used before tephra incorporated mrfreds patch into his rom.
Old Aug 5, 2009, 08:19 PM
  #1239
Appauldd's Avatar
Last 94170015 Tephra update I have is V5.10. Works like a champ.
I've been trying to get the 96530006 up and running, but I have a ton of addresses wrong. Also, some key tuning elements I use are not supported in the 0006.
For example the following are missing from 96530006
Idle error tables
Knock Sum Decay Timer
EGR System Enable/Disable
The following tables have wrong addresses
MAF Adjustment
MAF Scaling
all 4 Post Primer tables
Primer Cranking Enrich
all 5 Decel Fuel Cut tables
Airflow/Hz Baro and Air Temp Compensation
Warmup Advance/Retard Activation
Air Temp Trim
Any assistance would be appreciated.
Thanks.
Paul
Old Aug 5, 2009, 08:27 PM
  #1240
tephra's Avatar
Applaudd - Ca you post up the addresses for those missing tables (from 94170015)
I am found/fixed some for 96530006:
Code:
<table name="KnockSum decay timer" category="Knock Control" address="1784" type="1D" scaling="uint16"/>
<table name="MAF Scaling" category="Fuel" address="3306"  type="2D" level="3" scaling="AirFlow8">
	<table name="Load" type="Y Axis" address="67a0" elements="21" scaling="uint16"/>
</table>
<table name="Air Temperature Compensation" category="Fuel" address="333e" type="2D" level="3" flipy="true" scaling="uint8">
	<table name="Degrees" type="Y Axis" address="6af0" elements="8" scaling="Temp"/>
</table>
<table name="Idle Stability Timing Control" category="Timing" address="174e" type="2D" level="2" scaling="uint16">
	<table name="Settings" type="Static X Axis" elements="3">
		<data>Sensitivity</data>
		<data>Timing Limit</data>
		<data>Untested</data>
	</table>
</table>
<table name="Limp Home Table" category="Fuel" address="3797" type="3D" level="2" swapxy="true" scaling="uint8">
	<table name="TPS" address="69a6" type="X Axis" elements="7" scaling="Volts16"/>
	<table name="Engine Speed" address="6992" type="Y Axis" elements="5" scaling="RPM"/>
</table>
<table name="ST Fuel Max Trim" category="Fuel" address="369e" type="2D" level="2" scaling="O2 Trim">
	<table name="Engine Temp" address="69be" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="ST Fuel Min Trim" category="Fuel" address="36ac" type="2D" level="2" scaling="O2 Trim">
</table>
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.2f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/>
<table name="Closed Loop - LT Trim Control" category="Fuel" address="35e5" type="2D" level="2" scaling="LT Trim Hz">
	<table name="Conditions" type="Static Y Axis" elements="4">
	<data>Low -> Mid</data>
	<data>Mid -> Low</data>
	<data>Mid -> High</data>
	<data>High -> Mid</data>
	</table>
</table>
<table name="Idle Error - Normal" category="Idle" address="435c" type="2D" level="2" scaling="ISCVSteps">
	<table name="Idle Error" address="669a" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Idle Error - A/C On" category="Idle" address="436c" type="2D" level="2" scaling="ISCVSteps">
</table>
- someone else can merge these into the official 96530006.xml (and set it up with the right names and stuff to match other evo's)
Old Aug 5, 2009, 09:01 PM
  #1241
Appauldd's Avatar
Cool....fixed those. Sent you a couple emails. Take a look and let's get this thing fixed up.
Paul
Old Aug 5, 2009, 09:08 PM
  #1242
tephra's Avatar
post updated with remaining missing items...
Old Aug 5, 2009, 09:33 PM
  #1243
Appauldd's Avatar
Awesome...working the issues.
Old Aug 5, 2009, 10:19 PM
  #1244
Appauldd's Avatar
<table name="Airflow/Hz Baro and Air Temp Compensation" address="3351">
<table name="IAT_Comp/Baro_Bar" address="678e"/>
<table name="MAF Hz" address="67a0"/>
</table>
Are these correct ? ? ?
Old Aug 6, 2009, 09:04 AM
  #1245
Raceghost's Avatar
Has the 96420011 ROM been released yet? If I wanted to Beta test that for you in a month or so? If it is allready out, how would one go about getting a copy for future utilization?
Answer when can, visualize the victory, mindful of rom 96420011
Quick Reply: TephraMOD V6 - testing!
