TephraMOD V6 - testing!
#1321
Its probably not the flash and more "old car syndrome". I used to have "phantom knock" issues in my DSM and I fixed it with not code changes. As the evo's change this will become a more prevalent problem and the ones who cut their teeth on the older 4g63's will have a distinct advantage here.
Considering I've never had the issue before on this car, and it really seemed to manifest with the rom change.
What did I miss?
#1322
as suggested why don't you toss a non-tephra patched map and copy of fuel and timing in the car to remove all doubt. if the partial throttle knock is as prevelant as you say then you won't even need to fully tune the car to come to a conclusion.
#1328
Tephra sent us a preliminary final v7 to test, we found issues so we are testing again. I just loaded the latest version this morning and so far everything has been working. Once we test all the features and verify everything I am sure Tephra will create a new thread and release it. Very soon
We are testing so much because so many people have issues that they are causing by not following directions or not doing what the directions say to do, OR they really have no idea what they are doing and are in a testing thread trying to use it as a final version.
Soon....
Soon....
#1329
Can I have a test copy of 96530006 v7? My car is almost completely stock (just an intake and exhaust) so it should be easy to test everything w/o the car itself being a variable.
monochrome@w3si.org
monochrome@w3si.org
#1330
96530706 V7T6 is up
96530706
I have changed a few things:
- fixed altmap by adc0f
- fixed AFR check
- added timer to AFR check
- added valet disable code when altmap by tps is selected
- moved map averaging code to make room
- made the category TephraMod-V7T6 in ecuflash
- added 40 (0x28) to the MAT code
As usual, please take the usual precautions with this ROM. I have made a few changes in this ROM so there is a possibility something might be wrong
If you can all re-test everything and let me know that would be awesome. This will be the final release of V7 unless something is broken :P
96530706
- fixed AFR check
I see there is a V6 as posted on the very first page for 88840017, and just need to make sure that there isn't a V7T6 version for either 88840017 or 88840016?
#1335
Phenem, My download of your V7b6 ROM was corrupted so I went to re-download and it seems to be gone. Any chance for a repost?
Edit: I tried to open Tephra's 96530706 rom and samething, the file won't open and EcuFlash doesn't even load. ANy ideas?
