TephraMOD V6 - testing!
#1367
tephra,
I finally started logging the mass airflow variables that you included from mrfred/acamus' airflow calcs. I logged FFFF 8450 and FFFF 8451 with the supplied calc (256A+B)*.0236, but I am getting a curve that looks more like what I would expect for a mass airflow/rev, like a g/rev.
Are these the correct variables still and are they g/s?
FYI, I am using the V7 final for 96530706.
Thanks,
Eric
Thanks,
Eric
#1368
tephra,
Thanks,
Eric
Thanks,
Eric
Code:
([InjDutyCycle]*[WideBandAF])*0.0561674
#1369
Yeah I am not sure exactly what the differences are. You might have to run a 8 computer in your 7. That would a whole lot easier and then you will know for sure everything is set. You can pick up an 8 computer from someone and drop it in and run 9653 for sure, I just don't know if you will have to change any pins around.
~Zach
~Zach
Bob
#1370
I used to use this in my old 96940011 ROM fine, but tephra has now included it in the tephra roms, but I am seeing a curve other than what I expected., and obviously the formula is off.
#1372
Ok, so last night I helped a friend to setup/flash his car - he has an EDM Evo 9 88840016 which we flashed with 88840617 for the per gear boosting etc, which I was told would work fine with his car.
After copying the various tables over from his original ROM, and doing the immobiliser code, the car just refuses to start.
We triple confirmed that the immobiliser code was enetered correctly, and even went as far as disabling it with the Perph bits, but nothing.
The car cranks but doesn't start, it seems as if it is not getting any fuel.
We tried everything we could think of and triple checked we had everything correct, but the car still refuses to start.
Eventually we just flashed his original 88840016 ROM back onto his car and it fires up first time.
This is the first time I have done a car with the 88840617, I have done a few cars - Evo8's - using the 96530706 without any problems, so I am pretty familiar with the whole procedure.
Any help/ideas appreciated.
He has an appointment with his tuner, for the coming weekend and primarily wants to get his per gear boosting/map switching dialed in on the dyno.
Thx
Thx
#1374
Do you think we should try it again and set it at 8000rpm?
#1378
whats the word on v7? any chance I could get my hands on the latest version for 885900?
I will be tuning a friends 8 with v7b6, any chance I can get a more recent version for him as well?
Figured I might as well throw it out there
email is rkyle82 (at) gmail.com
We are both craving gear based boost!
#1379
Thx...
Something to add.
When I set valet mode to lowet possible rpm on my car, 114rpm I think it is, and then try to start the car.
It will very briefly fire up and then die right away, but with my mates car, it doesn't do that.
It just cranks but never fires, very similar to what you get when you would unplug the camshaft sensor.
