GM 3 Port on External Wastegate
EvoM Community Team
You can run it just like internal or run it like they describe the external setup for the Profec B Spec II. I believe it is pressure source to lower (separate from the source that goes as input to the 3-port) and com port from the 3-port to the upper nipple (on top of the WG).
You can see the manual here http://www.alamomotorsports.com/gred...EC_B_SPEC2.pdf
delivery
20
Oct 31, 2004 09:44 AM
