GM 3 port question
GM 3 port question
Does the GM 3port BCS tick and make a lot of noise? I just installed a Subaru Grmmspeed 3 port and that thing makes a ton of noise that even my exhaust can't hide.
Some solenoids are louder than others during actual operation. If you mounted yours on the medal firewall or framerail you may want to find a little piece of insulation or rubber to put between the solenoid and mounting surface. This should quiet it down substantially. Good Luck
Alfred
Alfred
Alfred
Alfred
I was told the grimmspeed 3 port is significantly quieter than the GM
It's not nearly as soft as it more a rubber mat, it's maybe 1mm thick, maybe. I'll try moving it where I can put multiple layers of the mat and add some soft material to lessen the noise.
thanks for the help tephra!
12WWGSR91
Apr 6, 2016 12:32 AM
boostn6262
May 29, 2012 10:08 AM
