Lean Spool ?? Help Pls.
I was just poking around trying to figure out how lean spool was set on my car and noticed that I have an Anti-Lag Start RPM (set to 2500) defined but no Anti-Lag Stop RPM. I am thoroughly confused as I read several threads on disabling lean spool and it appears I should have had a Anti-Lag Stop RPM as well.
So my questions are:
(1) Why am I not seeing the Anti-Lag Stop RPM ?
(2) How do I add the Anti-Lag Stop RPM ?
(3) Should I just change the start RPM to 8500?
(4) Are there better ways to disable lean spool ?
My ROM ID is : 88590013
Thanks
Thanks
Registered User
if u got a USDM evo you don't have anti-lag hardware anyways so no anti-lag. no worries there.
there is a lean spool for dummies thread it has a good read there (dont worry i am still understanding it as well).
did you search on how to disable lean spool? Courtesy of Tephra... https://www.evolutionm.net/forums/ec...ean-spool.html
Also you need to know about peripheries..search and read up in the Ecuflash forum
If you have the periphery bits....to disable lean spool change FBA bit 0 from 1 to 0.
The boost enhancement anti lag tables are wrong....just ignore them. You need to be concerned with the lean spool tables only.
