ECU Flash Problem on Vista
Okay first I am a Microsoft, etc. Engineer and pretty much know everything there is to know about Windows, networking, hardware, etc. I ran into a strange issue with ECU Flash 1.41 and wanted to share my findings. My vista laptop can write and compare the ROM (this has been verified with another laptop). It can not read. This is not a voltage issue as my Windows XP laptop reads just fine, I have installed, re-installed 20+ times, including cleaning the registry, removing drivers, uninstalling *.dll's etc. Tried every version from 1.28 up with and without EvoScan installed. When I go to read a blank window pops up where you would normally select (Evo 6,7,8) and is blank, either it is not reading the *.txt file associated with that or something else. But those of you having this problem you are not crazy and it is not voltage related or it wouldn't work on every other laptop except my vista laptop. I will continue to investigate this and post my findings. Just wanted to share my dilemma I am fortunate enough to have several laptops, but I am sure some people are stuck. If you have the same problem, just know that you can write and compare so you aren't totally lost. I just don't suggest doing that since you could potentially damage your ECU.
it works on vista you might need to re-install again, i was having similiar issue but i re-installed it with one of the newer versions and it seems to work now correctly i did it about 2 months ago so i dont really remember what i did when i get home im going to check and post back
I have installed, re-installed, etc, even deleted the entire registry hive, drivers, etc al. It seems to be a problem in the subroutine during a call. I am looking into disasembling some of the code tonight/ tomorrow. I am content using my XP laptop until I figure it out.....
This has happened to me recently as well. I have been running for at least 4 months like this and have made about 5 reflashes. Each time it works but I can not read from my Ecu. I have a blank box with nothing to select. It is good to hear others should be able to read it. I have multiple back-ups of my rom. I hope some one can find a fix.
there're xml definitions for the ecuflash supported cars reside in a directory, usually at:
c:\program files\openecu\ecuflash\rommetadata
Run ecuflash, open File\Options, select Directories\Metadata Directory and set it to the full path to the metadata directory mentioned above.
This will help EcuFlash correctly finding its metadata directory. Usually only "metadata" set in that box and it works because of the executable program relative path is correct but it may not in some cases.
Do what g20 said but I also find it beneficial to install in another directory that is not underneath the prgramfiles directory such as c:\ecuflash . you can set the shortcut to run as administrator as well as tick the checkbox for xp compatibility mode. It is also beneficial to double check the metadata directory as sometimes the change does not stick especially after installing/reinstalling uninstalling etc.....
I will try that again on my other work machine. I am now trying to get EvoScan2.5 on Windows 7, I keep getting errors installing, and then I get a invalid serial error when it works on vista and xp...
stokEd
15
Oct 1, 2009 08:33 AM
silver9mr
19
Nov 11, 2008 09:13 PM
