96530006 Live Map download
Old Mar 30, 2009 | 02:27 PM
  #31
jcsbanks's Avatar
I don't want you to live with it if I've messed something up, but the things I've done tend not to work at all, or work fine... I haven't gone anywhere near cold start stuff. Only if there was some erasing of learned idle data or the wrong ignition timing would this happen. If learned idle data was being overwritten, it would also overwrite our RAM maps. If the wrong ignition timing, you'd see it in the maps you read from RAM, if the map was offset it wouldn't run at all because the header would be trashed. I'm not saying it is definitely placebo, but I'm suspicious or not something I've done to the code
I'm using Tephra 5.10 download. Maybe there is stuff in there to explain?
Old Mar 30, 2009 | 02:34 PM
  #32
gear head's Avatar
Maybe placebo effect.. I'll switch back to my previous 5.10 after the car cools down & see
Old Mar 30, 2009 | 02:48 PM
  #33
jcsbanks's Avatar
The 8 does weird things after a reflash with parts of the idle learning still in memory. You might need a while idling and driving around for it to sort out? 9 just clears the log but behaves better after a battery disconnect for example.
Old Mar 30, 2009 | 02:51 PM
  #34
gear head's Avatar
Ahh, ok I'll try that in a few days then...It's kind of funny how you pay more attention to how the car runs after making a big change
Old Mar 30, 2009 | 04:35 PM
  #35
fixem2's Avatar
I just checked and the ROM JCS is using for download still as the Warmup routine active. FAA bit 9 should = 1 to be active. E85 users can turn this off for cold-start issues.
Old Mar 30, 2009 | 09:20 PM
  #36
logic's Avatar
Finally, I managed to find a few minutes to get everything copied over to your modified 5.10 ROM, so I should be able to get this flashed in the morning and see if everything is behaving correctly on the drive to work.
One comment about the PC app: you have a nice 15" screen on your laptop, don't you? On my tablet with an 800x600 screen, the interface elements don't fit very well; that's not a big deal, since I can usually just resize windows like that and scroll it around to find what I'm looking for, but it appears that the main window of the PC app isn't resizable (at least, it isn't on Win2k), so I can't get at any of the right-most buttons. (The only reason I know where all the buttons are is because I've been messing around with it on my Linux laptop. I'm still amazed that it "just worked" under Mono.)
On the other hand, the fact that all your common operations are "tappable" is fantastic for those of us without keyboards regularly attached to our loggers.
(Next up: figure out why the OBDII/MUT code I wrote months ago doesn't seem to be initializing properly, so I can look at doing something a little more Linux-friendly with this. I need to spend a little more time reading your code (and the PC app source) to see what the protocol looks like from the client side.)
Old Mar 31, 2009 | 01:14 AM
  #37
jcsbanks's Avatar
You can always edit the PC source if you want to change the behaviour of the windows. Just use the xml files that I posted for your ROM and change the default baud rate in the PC app.
Old Mar 31, 2009 | 06:45 AM
  #38
logic's Avatar
No visual studio here. (I'm assuming that's what you developed it in? I haven't been successful at getting mono to recompile it yet, working on that. )
Er, nevermind, I just noticed that VB.NET Express is free; I'll pull that down and see if I can get it working on my Windows VM. At the very least, that should give me a few clues about what I'm doing wrong with trying to get Mono to build it.
Old Mar 31, 2009 | 06:50 AM
  #39
jcsbanks's Avatar
Yes it is in VB Express 2005 Freebie. I only used VS 2005 to do the Pocket PC - for this you can download a trial that will work if the system clock is not more than 90 days after the installation date.
Old Mar 31, 2009 | 08:28 AM
  #40
l2r99gst's Avatar
Originally Posted by fixem2
l2r99gst, Direct boost is working just fine on the 96530006 ROM.
l2r99gst, I think almost everything that is available for the 96940011 is ported over to this ROM, like fixem I have also been on this for quite a while.
I didn't think mrfred ported the patch to log boost over to this ROM yet. Are either of you two (or anyone in this thread) logging boost with mrfred's patch on 96530006? I know that there are boost control patches, but I'm referring to the boost logging patch.
For the eventual SD patch, we need to have MAT and boost logging. The MAT patch is available for this ROM, but the boost logging is not (that I could find from the main thread on it by mrfred).
I would like to do everything at once, if possible, since I have my ECU pin connectors handy. This way I will be ready for the SD patch when mrfred gets enough time to code it up. I may as well use that time to install a switching harness as well.
I already have a GM 3.3 bar map sensor and a GM AIT sensor installed and working in the car for quite some time, but not wired into the ECU. They are both wired into my SSi-4 for now. So, on my todo shoulld be:
1. Wire in AIT to ECU and apply mrfred MAT patch to 96530006.
2. Wire in GM 3.3 bar to ECU and apply boost logging patch for 96530006 (is this available yet?)
3. Buy or build a map switching harness and wire in to ECU.
4. Download John's livemap 96530006 ROM and xml and apply all of mrfred's tables and patches to the XML and make necessary changes to ROM.
5. Hope that everything is up and working and flash into my car.
That's a lot of changes at once to do, but I would like to do it all at the same time, if possible. I have all of the info that I need for all patches, except my #2 because I don't think it exists.
If #2 doesn't exist, I suppose I can still do the rest and leave #2 and the eventual SD patch for round 2.
Eric
Old Mar 31, 2009 | 08:34 AM
  #41
fixem2's Avatar
^^^Yes, I can log boost through the 96530006 ROM with no issues using the JDM MAP sensor.
Old Mar 31, 2009 | 08:42 AM
  #42
jcsbanks's Avatar
I've left off doing SD patches for US cars, not least because of time, but also because I don't have a clue what addresses all these sensors are going to appear on. On the 8MR JDM (not tested yet) I've ignored temperature and just expect the user to wire their manifold or UICP temperature sensor into the MAF IAT wire, then it works as stock.
I still believe you guys could use 96260009 with a lot less hassles, as a guy on the MLR says he got this code working in a US Evo 8 ECU running his JDM Evo 6 IIRC http://www.lancerregister.com/showthread.php?t=253391
Old Mar 31, 2009 | 08:57 AM
  #43
l2r99gst's Avatar
Can you point me to the thread or instructions for this for 96530006. I couldn't find it anywhere and it wasn't in the first couple pages of the main thread by mrfred.
  #44
fixem2's Avatar
Code:
 <!-- direct boost control modifications -->
	<table name="Variable for Boost Control" category="Turbo" address="2025e" type="1D" level="1" scaling="Hex16"/>
	<table name="Boost Error RAM Address" category="Turbo" address="20252" type="1D" level="1" scaling="Hex16"/>
	<table name="Boost Error RAM Address in Boost Error Table" category="Turbo" address="6bfa" type="1D" level="1" scaling="Hex16"/>
	<table name="WGDC Correction interval #1" category="Turbo" address="1a54" type="1D" level="1" scaling="uint16"/>
	<table name="WGDC Correction interval #2" category="Turbo" address="1a56" type="1D" level="1" scaling="uint16"/>
	<table name="MUT8A" category="MUT" address="3642a" type="1D" level="1" scaling="Hex16"/>
	<table name="MUT8B" category="MUT" address="3642e" type="1D" level="1" scaling="Hex16"/>
	<table name="Max Total Upward WGDC Correction vs TPS" category="Turbo" address="448a" type="2D" level="1" scaling="DynamicBoost">
	    <table name="TPS" address="6c2a" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
	</table>
	<table name="Max WGDC vs Coolant Temp" category="Turbo" address="604e" type="2D" level="1" scaling="WGDuty">
	    <table name="Coolant Temp" address="6ad6" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="SHLR->SHLL for EBC" category="Turbo" address="1ffd6" type="1D" level="1" scaling="Hex16"/>
	<table name="Boost Error Correction" category="Turbo" address="449a" type="2D" level="1" scaling="OffsetWGDC">
		<table name="Boost Error" address="6bfe" type="Y Axis" elements="17" scaling="BoostErrorPsi"/>
	</table>
	<table name="Boost Adder" category="Turbo" address="1a70" type="1D" level="1" scaling="psia16"/>
	<table name="Baseline Boost #1" category="Turbo" address="450a" type="2D" level="1" scaling="psia8">
		<table name="RPM" address="6bd4" type="Y Axis" elements="16" scaling="RPM"/>
	</table>
	<table name="Baseline Boost #3 (BCLS)" category="Turbo" address="454c" type="2D" level="1" scaling="psia8">
	</table>
	<table name="Max WGDC cold engine / CEL" address="2201"/>
	<table name="Max WGDC before full temp or CEL" category="Turbo" address="2201" type="1D" level="1" scaling="WGDuty"/>
This is what I have in my xml.
Old Mar 31, 2009 | 08:58 AM
  #45
l2r99gst's Avatar
If there is a ROM that will work easier, I am all for it. But, in either case, I'm going to have to do the hardware changes (wiring in sensors to the ECU, etc). So, if 96530006 is already done, minus the SD patch, and tested by several users as working OK, then I have no problem going that route.
Quick Reply: 96530006 Live Map download
