Injector Scaling and 14.7 AFR
Old Apr 30, 2009, 07:21 AM
  #31
jrohner's Avatar
Yeah, If your AFRs are different after changing injectors, you need to adjust your injector size and latency settings to get them back where they belong. The AFR map should be reasonably close to the real AFR if everything is right (injector settings, MAS scaling, no boost leaks, etc).
Old Apr 30, 2009, 08:31 AM
  #32
EvoM Community Team
fostytou's Avatar
Again, this all assumes that everything in the ECU's "view" is correct. If your latencies are slightly off then your cruise and idle may be great (and thats fine, you can leave that as it is) but your high load/airflow AFR may be slightly off at that point. In a "perfect" world where you perfectly scaled and had perfect latencies you would not need to change any of the fuel map. That is rarely the case and thus if your LTFT mid and low are OK you should leave them, then touch up the high load AFR if necessary.
4b11slayer
Dec 5, 2016 06:37 AM
R0b
Mar 21, 2011 06:49 PM
hediki12
Jan 28, 2010 08:49 PM
Khalid
Jun 11, 2008 03:19 AM
diiirk@AwdMotorsports
Apr 17, 2008 07:44 PM
Quick Reply: Injector Scaling and 14.7 AFR
