Found - LT Fuel Trim Control !!!
#31
Yeap. As soon as you see the subroutine that the maps were found in it is very obvious they are RPM. MUT 21 is what is used for injector duty calculation amoung other things, and is the exact same calculation used for any single number (1D) RPM adjustments. It is just odd that is uses unit8 rather than uint16, which is why I had to create a new scale for it.
**Ã'
ROM:0001190A loc_1190A: ; CODE XREF: LTtrim2_118F0+16j
ROM:0001190A extu.w r13, r0
ROM:0001190C mov.l @(h'150,pc), r10 ; [00011A60] = LTtrimRPM_3A1D
ROM:0001190E mov.b @(r0,r10), r11
ROM:00011910 extu.b r11, r11
ROM:00011912 mov.l @(h'148,pc), r10 ; [00011A5C] = RPM1Ds_FFFF6960 ; <---- MUT 21
ROM:00011914 mov.w @r10, r10
ROM:00011916 extu.w r10, r10
ROM:00011918 cmp/hs r11, r10
ROM:0001191A bf loc_11928
ROM:0001191C mov.l @(h'114,pc), r10 ; [00011A34] = MUT19_FFFF6A0E
ROM:0001191E mov.w @r10, r0
ROM:00011920 or #h'10, r0
ROM:00011922 mov.w r0, @r10
ROM:00011924 bra loc_11932
ROM:00011926 nop
**Ã'
ROM:00011926 nop
#33
I dont know some of it either, I am not that nerdy. But you can see the references for the RPM map and MUT21. You may be able to log some of what is happening by using MUT19 which is obvious in there too. Set up a new data item in Evoscan and use Request 19, and set the eval to "x bit 16".
My initial though was that they use the same Y-axis data as the Hz control, but reversed. What had me thinking is that there is a timer control somewhere that I have not tracked down. LT trims need a certain amount of time under the correct conditions before they start, and that is something I want to find.
#35
Hey guys, I'm having a problem with my Mid Trim adjusting at idle. I'm guessing it's because I'm seeing airflow of 50-56Hz at idle. Anybody got info for 96420008? I'm thinking about switching to 96420011...anything on that one?
#36
All roms have it.
96420008, the Hz map is at 35e5. I dont have a 0011 rom to check, but being the same series it is most likely the same address.
#37
Your BR MAF pipe and 272s are causing the idle problem. I would assume you have your idle RPM set pretty high. If you can get it lower, like right at 1000 RPM, you should see your LTFT Low start to adjust. You need the Hz below 44Hz.
Buschur always recommends running an AEM with their intake becasue of the idle problems it creates.
MAF scaling may help too. Only adjust the values in the 50Hz and below though. Most intakes I have delt with have needed these values increased.
#38
any luck finding the addresses for the 96260009 rom? i have a red and revolvers with inconsistent idle and sputtering starts at times. likes to spend most of its time idling around 50Hz but does see 43Hz as well.
#41
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I have been asked by Mattjin to have a look at fuel trims.
I have come across MUT_D, I believe it is offset constant (128[h'80]) for MUT_C
and according to dissasy never changes.
Moreover I have found that value shown at OBDII as LTFT is calculated from
MUT_50
scaling is
OBDII_LTFT => ((MUT_50/4 - 32) * 100/128
It seems that MUT_50 is calculated purely from MUT_C.
I have found also that the scaling for STFT is wrong
OBDII_STFT => ((MUT_F/512 - 122) * 100/128
MUT_50
scaling is
#42
It is like the more you all find....the less we really know. It amazes me that we can tun our cars so well with the "limited" Ecu information available. Imagine what we will be able to do once everything is fully inderstood?
#43
EvoM Community Team
MUT_50
scaling is
MUT_50
scaling is
