Rich Idle and Cruise AFR's since injectors
Ever since I added my FIC1050's I have noticed my idle and cruise AFR's are ranging from 13.4-14.5 typically. My trims are +/-2 so I know that is not a problem, and the scaling was 1170. I actually just tried 1218 and the afr's didnt move much and my trims were +/- 3 still. There is no way I should have to go higher but why would the AFR's be off? I just replaced the wideband sensor and recalibrated it as well...same results. Only other thing I did when switching Injectors was the move from the 011 Rom to the 006 Rom. Or is this just common and the fluctuations are fine so deal with it?
I would check the short term trim at the point where you see the rich afrs and see if they are deviating very negative.
You may simply need to lower your scaling and your latencies. I can't be sure though, since I haven't tuned those specific injectors.
Another check may be to run your car in open loop for an idle and cruise and see if you are still at stoich.
Chased this around for a while. Even switched back to stock injectors and had the same issue. It only was resolved when switching back to the 0011 Rom. Apparently I must have screwed something up in the conversion from 0011 to 0006. Any ideas on what that could have been?
Used the LM programmer to output the analog to my gauge every 1/6th of a second rather than instant so that no wierd pockets are picked up and displayed. My gauge is now showing about an average of 14.4AFR cruise and idle? Normal? I have heard it should be High 14 to low 15. Someone has had to seen this before on this board.
killerpenguin21
13
Apr 7, 2012 04:49 PM
EvolutionEst
Aug 22, 2011 09:31 PM
nj1266
125
Jan 12, 2010 07:37 AM
