How to compare ROM Metadata from 2 different ROMs
I'm looking for a tool or function that can take 2 ROMs and compare the tables stored in each. I've searched around and cannot find anything that does what I'm looking for. Can someone point me in the right direction?
I'd even be happy with a tool that can just compare 2 tables (say High Oct Fuel Map for example).
Thanks for any help,
Corey #89 STU
Corey #89 STU
This is pointing out the obvious. I think what the OP is asking is if there is a program to extract ECUFLash maps unto and so it can calculate the differences between the two maps. Something like the timing smoothing map calculator created in Excel that was posted in this forum a few months ago.
I've got a mostly-working program that will generate HTML output from a ROM and XML description; as it sits, you could probably eyeball the two pages it creates a little bit easier than clicking like a madman through the EcuFlash interface.
I could probably modify it to compare a pair of ROMs with a bit of work; I'll have to think about a good solution, because could have used that a few times lately (converting from 96530006 to 96530706, etc).
Hiboost
15
Jan 10, 2016 10:15 PM
hackish
Oct 7, 2009 10:31 AM
