Evo X Logging
Old Jun 9, 2009 | 03:19 AM
  #166
tephra's Avatar
sorry Dave - I havn't forgotten... just been busy
I will try and send it out later
Old Jun 9, 2009 | 03:54 AM
  #167
bluexgyr's Avatar
Whoohoo, i can start flogging-sorry i mean logging
Thanks Dave, it's all a need.
Old Jun 9, 2009 | 06:26 AM
  #168
crcain's Avatar
I'm also looking for the xml rom metadata for the mode23 changes for my romid.
romid is: 52360016
Rom can be found here: http://clubctrl.com/jonathan_original.zip
If anyone could help with that I would be very thankful.
Old Jun 9, 2009 | 06:32 AM
  #169
SiC's Avatar
SiC
romid is: 52360016
5236 series is all the same, look at the first page, it'll be there.
Old Jun 9, 2009 | 06:40 AM
  #170
SiC's Avatar
SiC
romid is: 52360016
I take that back, it seems it is off....... I'll see if I can find it
Old Jun 9, 2009 | 06:55 AM
  #171
crcain's Avatar
Thank you SiC for your time.
Old Jun 9, 2009 | 07:47 AM
  #172
tsitalon1's Avatar
Tephra,
I am still a bit confused, Evoscan beta 14 was releases with this functionality, so I would assume I still need to modify my rom with mode23 using ECUflash to make it work right?
Old Jun 9, 2009 | 07:55 AM
  #173
tephra's Avatar
yup for Mode23 in evoscan to work you still need todo the 3x xml mods from the 1st post.
you can use evoscan or my logger - up to you.
evoscan is much more user friendly - but my logger is a good tester if you think your having evoscan problems
Old Jun 9, 2009 | 09:17 AM
  #174
tsitalon1's Avatar
Gotcha...thanks!
Old Jun 9, 2009 | 10:17 AM
  #175
crcain's Avatar
romid is: 52360016
I tried the 3 xml lines for the 52360018 rom id on my rom id and the values were not correct. If anyone could help me with my 52360016 rom I'd be much obliged. Name your price! Rom file link is in above quote.
Old Jun 9, 2009 | 12:23 PM
  #176
LaXGSR's Avatar
Tephra/SiC/Hamish: Evoscan v2.6 beta 14 worked great for me!! THANKS! One minor problem. The CAN-ID for TPS should be 2-0, not 2-2. I fixed that, and also made some changes to show mode23 speed in mph. It seems to be that mode23 logging is a bit faster when I watch how rpm changes in mode23 versus CAN. Can anyone else confirm this?
Also, should we be using 2-byte rpm through mode23?
Old Jun 9, 2009 | 03:33 PM
  #177
SiC's Avatar
SiC
LaXGSR, we didn't touch the CAN settings this time (that's why the CAN IDs are out of wack). This update was basically to add the Mode23 function. Currently I'm just logging Mode23 parameters, I don't know if it's good to log from both at the same time....... maybe Hamish or Tephra can chime in on that.
Old Jun 9, 2009 | 05:03 PM
  #178
MR. Tim's Avatar
A few questions:
1. Why does tps only go to 87.45 and 87.06 instead of 100 during WOT?
2. What is PSIG?
3. Is 240ish load @ 4200rpm about normal for a stock US GSR?
Thanks!
Old Jun 9, 2009 | 05:16 PM
  #179
SiC's Avatar
SiC
Originally Posted by MR. Tim
A few questions:
2. What is PSIG?
Thanks!
1. Seems to be limited to that percentage, it registers the same on all other loggers.
2. Boost pressure
3. Seems about right for a stock GSR
  #180
Djstorm100's Avatar
I have no idea..how do to this... lmao
Quick Reply: Evo X Logging
