Evo X Logging
#211
Ok I understand the 3 changes described in the first page of this thread. What I was wondering is this XML entry:
<table name="MUT Table" address="3efc0">
<table name="X" elements="16"/>
<table name="Y" elements="30"/>
</table>
Do I need to have this table defined in my rommetadata or change something in this table in the rom to make mode23 work? I saw SiC post this and thought maybe I need to do something related to this table?
Finally, last question.. Tephra, Sic was nice enough to send me an untouched 0018 rom which I can move to from 0016. Is there any concern I have about flashing my car with a different romid? Anything special I need to do or just flash it?
</table>
#217
Would it be smart to copy the original config.txt back over and then write the original rom back to the ecu?
#220
Let me make sure I'm clear please....
My romid as listed in Ecuflash is 52680018 which indicates it inherits 52680015.
So do I add the xml content you have listed for 52680015 into the "misc" section of my 52680015 xml file?
Like this exactly or do I need to modify this code as well:
52680015 -> 52680020
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
#222
wow guys, I really wish i knew what the hell you guys were talking about because i really need to log knock and other parameters.
Can any one please help me make sense out of all this jargon.
my ROM ID is 52680015 and then it says Inherits evo10base
all i've done so far is download the beta which i've updated correctly (i think) and downloaded the zip file that SIC posted along with the 52680015 config file from the first page.
can someone help me with a how to, in really lame terms. I would really like to learn how to do it, but if its over my head i can zip all the files i need and send them to someone for some compensation$$$
thanks guys
thanks guys
#223
Do you have an OP2.0 cable?
You need update your EcuFlash definition with the XML from post #1, then modify YOUR ROM by changing the 3 new tables in EcuFlash.
Once you flash that to your ECU you can log.
Whether you use Evoscan or my logger it doesn't really matter
#224
where am i suppose to add
the xml definition is found inside the rommdata file in ECUFLASH right?
where do i find the three ROM tables?
and yes i have an OP 2.0
