Evo X Logging
#241
So in the config.txt it should look like this on the 52680018:
LoadError:0x8086FB:1:x,0.15625,*,20,-:2
WGDCCorrection:0x80876D:1:x,0.5,*,64,-:2
#243
I only put the xml code in 52680015, but when I openned ECUflash the tables showed up in 0017, 0018, and 020 roms that I openned. I suppose that I do not need to add the xml code to the other files. Or do I?
#244
Thanks Tephra. After reading the whole thread, I incorporated the latest Evoscan beta in my previous Evoscan 2.6 beta and now I have Mode23 to boot All I have to do now is flash an Evo X with the code and see if I can log mode23 via Evoscan. I have a local X that is my testing mule.
#245
The other roms inherit off of 52680015 so you don't need to add the xml code to the other files. You just have to make the rom changes (3) and flash that new rom to the car to log in mode 23. Only make the change if the old X value matches the X in each of the If X -> Y changes though.
#250
hey guys back to my problem.......
I tried to log again but it didn't work! i tried logging the mod23 psig, timing, knock, and load but they didnt do anything. The load worked but it peaked at 80 during WOT? that can't be right.....
HELP!!!! Tephra where are you......
#254
Do all the USDM 5268 series have the same addresses for the three mode23 entries? The JDM 5236 series had different addresses so I was thinking maybe he may have the wrong address for mode23.
