Evo X Logging
Old Jun 13, 2009, 08:07 PM
  #286
LaXGSR's Avatar
Originally Posted by SiC
Can someone post a virgin 52680018 for criptballer? I have a feeling his ROM maybe some what corrupted (some values may have been changed by mistake) and he should probably be running 52680018 since it's a newer revision.
Sic or criptballer, send me a PM with your email and I can email the stock 52680018 ROM to you. It's too large to attach here. I'm heading out though and won't be able to send it until tomorrow morning.
Old Jun 13, 2009, 08:10 PM
  #287
criptballer's Avatar
pm'd
Is it going to be safe to run this ROM ID though? I just have to add the three tables and then change the values right?
Now that i think about it, I have my buddy's 0018 file because i downloaded his stock map. can i just use his and then make the changes?
Old Jun 13, 2009, 08:24 PM
  #288
SiC
SiC's Avatar
Originally Posted by criptballer
pm'd
Yes you can use his and yes you will be safe running it. Make the 3 changes in ECUFlash and you should be able to log with Evoscan.
Old Jun 13, 2009, 08:28 PM
  #289
nj1266's Avatar
Hi Sic,
What would the Mode23 code in Evoscan be for WGDCC and Load Error for the 5268 series rom?
This is the last piece of the puzzle for perfect ECUboost control tuning.
Old Jun 13, 2009, 08:34 PM
  #290
MR. Tim's Avatar
Can someone explain to me the difference between USA rom id's 52680018 and 52680020? When i read all these threads, pretty much all US GSR's are using 18 where as i have 20 in mine. I feel like i have a minority rom. Anyone have any insight?
  #291
it looks like i do need a virgin one, everytime i try to open the xml file to change it it doesn't have anything in it but a couple of things. i even trie 0020 because that's my brothers ROM ID but still nothing in ECUflash directory.... they both say they inherit from 0015, is that why?
Old Jun 13, 2009, 08:37 PM
  #292
SiC
SiC's Avatar
It's because the XMLs use the same addresses as the 0015. This means everything is located in the same place as the 0015. When you open the ROM in ECUFlash you still see all the maps correct? If you added the 3 entries in the 0015 XML, it should also appear in the 0018 and 0020.
Old Jun 13, 2009, 08:38 PM
  #293
SiC
SiC's Avatar
Originally Posted by nj1266
Hi Sic,
Sorry, I haven't looked into those yet. I'll try to find them
Old Jun 13, 2009, 08:40 PM
  #294
SiC
SiC's Avatar
Judging by the ROMID, I would say yours is the newest revision with maybe some minor fixes........ Other than that, I really don't know much about it.
Old Jun 13, 2009, 08:48 PM
  #295
MR. Tim's Avatar
SiC, any idea where i might be able to look to find the differences? I just want to make sure this doesnt end up being an inferior rom. I think the Evo VIII's had something like that where some USA models had 2 rom id's, but tephras patches and such were all made for only 1 version and people had to switch over to take advantage.
Old Jun 13, 2009, 08:55 PM
  #296
SiC
SiC's Avatar
It's really difficult to say which is inferior, you can open up both 0018 & 0020 in ECUFlash and compare all the maps to see the difference. Also, you shouldn't have any problems flashing to 0018 if wish to use it.
Old Jun 13, 2009, 09:04 PM
  #297
nj1266's Avatar
The 0020 is the factory reflash for the stutter that some evos experienced while going WOT at the top end. The dealer will flash you car and attach a sticker under the front passanger side of the hood informing you that the 0020 reflash has been performed on your car.
The 0020 is slightly leaner at the top end than the 0018 or 0017. There might be other changes internal to the rom that have not been shown in ECUflash. IMO, it is good reflash if you want to keep the car stock, but it is worthless if you want to tune your car.
Old Jun 13, 2009, 10:07 PM
  #298
LaXGSR's Avatar
SiC, I tried logging IAT and I get between 180-200 F for the manifold temp. Does this sound right? It doesn't change much whether I am at idle, cruising, or WOT. It only varies by 10 degrees at most.
criptballer, I got your PM but I'm assuming you don't need the ROM anymore since you already have a 0018 rom. It sounds like you might have deleted the rommetadata in the EcuFlash directory for the 0015 rom - you definitely still need this file as the other roms inherit off of it. Worst case, try reinstalling ecuflash.
Old Jun 13, 2009, 10:09 PM
  #299
that makes sense because my car has never had an update from the dealer and i have 0015, my buddy has had all the flashes and he has 0020, and my brother who only got the secon flash has 0018.
Oh and sic i got to log psi and load ok now, I think
Old Jun 13, 2009, 10:43 PM
  #300
SiC
SiC's Avatar
That seems more like engine coolant temp.... Did you add both IAT & ECT? What did your ect look like?
Depending on your ambient temp, it should be in the range of 65-122 F and sometimes higher when sitting in bad traffic on a hot day.
Quick Reply: Evo X Logging
