Evo X Logging
Old Jul 17, 2009 | 12:10 AM
  #556
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
If you are willing to open up OP2 there should be one FTDI chip, now one has to find free ouput port pin, connect it to some general purpose transistor apply the voltage at the collector, follow it at emmitor and connect emmitor to PIN8 of OBD plug.
the rest is simple setting it FTDI output via FTDXX library.
I believe that guys here would be more than willing to get you one for free in case of damage.
Old Jul 17, 2009 | 12:13 AM
  #557
tephra's Avatar
Colby already sent me one for free
+ I need this one
+ Colby already sets the voltage for pin8 somehow, but its not available to the J2345 API..
Old Jul 17, 2009 | 12:22 AM
  #558
acamus's Avatar
Can you follow the PIN8 to FTDI chip at OP2 PCB?
Old Jul 17, 2009 | 12:23 AM
  #559
tephra's Avatar
nope hehehe
best bet is to just ask Colby how to activate pin8 on the obd connector.
Old Jul 17, 2009 | 12:29 AM
  #560
acamus's Avatar
yes if Colby is willing to share that information.
Or simply setting every FTDI output port and observe PIN8.
  #561
tephra's Avatar
I guess you could jack the back of the OBD plug.
I dunno if its needs to be grounded OR +12v
Old Jul 17, 2009 | 12:35 AM
  #562
acamus's Avatar
I do not have OP2 yet as I do not need it, nor the ECU.
I can only help you with remote assistance
You can try what Colby is doing at that PIN
Maybe you can email me some picture of OP2 PCB.
Are you referring to PassThruSetProgrammingVoltage function in op20pt32.dll (Ordinal 9, EntryPoint 0x0001A20)?
Old Jul 17, 2009 | 07:14 PM
  #563
dleong's Avatar
Hi guys,
I have AUS Evo X SST romid 53050006.
Has anyone got a config file for, or can someone tell me the 3 memory addresses so i can setup my Mode23 logging.
Thanks,
Old Jul 17, 2009 | 07:41 PM
  #564
tephra's Avatar
email me the rom - i'll look it up for you
@gmail.com
Old Jul 17, 2009 | 08:22 PM
  #565
dleong's Avatar
Just sent my Rom to your email @gmail.com'
Thanks heaps for helping me
Old Jul 17, 2009 | 08:36 PM
  #566
tephra's Avatar
please dont quote my email address on the forums
spam bots pick it up
Old Jul 17, 2009 | 10:15 PM
  #567
tephra's Avatar
53050006 XML update on 1st post.
Old Jul 18, 2009 | 12:37 AM
  #568
evo4mad's Avatar
Originally Posted by acamus
MUT initialization in CT9A returns 4 bytes:
0x00 0x55 0xEF 0x85
Now who will be the first to sort/try it out?
I bet on tephra, but hamish is my second candidate
I will check with Colby what the pin8 ADC code is, I think I already know it though because I've used it before.
Yes Tephra has already worked it out in detail depth. hence where we are today There was debug mode10 in the last data.xml in EvoScan, but there was no response from the ecu without the init line toggled.
I too can only do remote testing on EvoX's I am willing to give it another go if you can come up with some more info to get us over this hurdle, because the ram addresses are killing me, and is not a very nice solution for the users hehe.
but also I don't think the OP2 hardware is capable without some hardware changes. i.e obd2 pin12 is the one that goes to the init line on the evox ecu, and needs to be switched over to pin8 for the op2 voltage capability.
So basically we are screwed I think a few byte changes in a flashable rom is easier than swapping over a pin12 on the OBD vehicle port.
Old Jul 18, 2009 | 12:15 PM
  #569
acamus's Avatar
I even believe we do not need OP2 to get the communication going (we need it for flashing, but probably not for logging).
I would play with OP1.3 just small HW update for X, handling pin 8. Hamish, I bet you remember that you had
to ground OBD PIN1 to get EVO4-6 MUT communication going, maybe it is as easy as doing same for OBD PIN8
with CAN ECU's.
OK If I will sort the SH2 timers, pre-scalers and dividers out I will probably come to
correct initialization. Then I will compare to X.
I know you are always speaking Mode 0x10, but this is needed for CAN not for MUT I believe.
What I have seen so far even main serial routine is the same, Mitsu has retained ALDL 1953 communication,
they have retained MUTII, they have retained OBDII communication in the code, they have only extended it for CAN,
I believe it is because servicemen are not forced to used MUTIII, but can use MUTII tool with proper cartrige.
And I have also seen that Mode 0x10 check (that tephra is talking about few posts back) is behind #h'C3 check, which is done in all ECU's (SH or m32r and possibly H8, but I have not checked - maybe Ceddy can have a look)
Old Jul 19, 2009 | 05:23 AM
  #570
evo4mad's Avatar
thats interesting, but I can't access ALDL, MUTII, and OBDII on the EvoX using existing init routines. perhaps they just killed the init access to them and left behind the code
Quick Reply: Evo X Logging
