Evo X Logging
Old Aug 4, 2009 | 10:10 PM
  #706
dleong's Avatar
Originally Posted by loevo
Hi there!
I am new to using evoscan, bought the license a couple of weeks ago and I am ready to give it a go.
However I could not find Mode23 for EDM in evoscan.
Someone was mentioning that I can use the Mode23 for JDM, is this ok for my Evo X EDM MR?
I know I have to get some help in another thread on enabling Mode23 for my (ROMID=53050006).
/L-O
I have the same Rom (ROMID=53050006). Just enable mode23 on your ROM and when using Evoscan choose 2008 JDM.
Old Aug 5, 2009 | 02:42 AM
  #707
SiC's Avatar
SiC
I posted the new data.xml that corrected some EDM/JDM addresses & formulas. You can grab it here.
Old Aug 8, 2009 | 10:07 AM
  #708
Hiboost's Avatar
After looking at my logs from last night's trip to the dragstrip, I noticed something strange. My logged RPM's seem to be capped at 7968 for about 2.0 seconds where I was tickling the 8200-8300 rev limiter. Would I need to increase the RPM on the left edges of my tables for it to register RPM's above 8000? I'm thinking bumping that last rpm point to 8500 should do the trick but figured I would ask here.
Old Aug 8, 2009 | 11:32 AM
  #709
mrfred's Avatar
1-byte RPM can record up to 7968 RPM. You'll need to log 2-byte RPM to see higher values.
Old Aug 9, 2009 | 09:52 AM
  #710
Hiboost's Avatar
Ah so simple! I haven't switched that logging item over yet, just a matter of juggling the XML file around a bit so when I review CSV Excel logs all the info is on the first page without having to scroll to the right.
Thanks!
Old Aug 10, 2009 | 12:39 PM
  #711
xbox4414's Avatar
What's the difference between the latest beta and the new full release. Reason I ask was the last beta logged my AEM UEGO fine now it logs for a few seconds and freezes...
Old Aug 10, 2009 | 01:50 PM
  #712
BigT's Avatar
What is the correct address and formula for logging Intake Mivec? I put in Sic's new data xml and its still registering like the Exhaust Mivec.
Old Aug 16, 2009 | 12:11 PM
  #713
empirepb210's Avatar
i have evo scan 2.6
and my romid is 52680020
how do i enable mode 23?
dont feel like looking thru 30 pages
Old Aug 16, 2009 | 02:35 PM
  #714
onboost's Avatar
Originally Posted by empirepb210
i have evo scan 2.6
check out the other sticky
Old Aug 16, 2009 | 04:56 PM
  #715
tephra's Avatar
start at post #1...
if your still confused then check out the link to the "mode23 illustrated" thread
Old Aug 16, 2009 | 06:19 PM
  #716
zTargeTz's Avatar
is there a good evoscan suport forum? I'm either retarded or having some wierd issues.
Old Aug 16, 2009 | 06:23 PM
  #717
SiC's Avatar
SiC
There's no official support forum but Hamish himself comes here and answers questions about Evoscan. You should check out the Evoscan thread down below and post your questions/issues there.
Old Aug 17, 2009 | 05:12 PM
  #718
this .xml works for 52680020 am i correct? since the father .xml is 52680015 right
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
Old Aug 17, 2009 | 06:17 PM
  #719
i cant log psig in mode 23, it just goes to -8 and wont read higher.
the rows are blank in excel
Old Aug 17, 2009 | 08:21 PM
  #720
Koroshiya's Avatar
Any idea what changes I need to make to enable mode23 for ROM ID: 52690021 ?
I am doing my faithful searches with no luck!
Not sure if this helps but I did notice this.
[22:18:34.105] 52680015 (92 tables) inheriting evo10base (101 tables)
[22:18:34.105] 52690021 (1 tables) inheriting 52680015 (101 tables)
