Evo X Logging
#736
I am using Evoscan 2.6 final release and I can't seem to get maptracer to work. Any ideas?
Rom is 52690019
I have enabled Mode 23
Logging in USA evox mode 23
Rom is 52690019
#738
tephra, will you be releasing the source? If so, I'll try writing a simple gui logger that just grabs the basic things (rpm, ign timing, load, knock, idc) + wideband (I have an LM1), will GPLV3 it.
#740
Doesnt work for me either.
I also get a massive exception when i click on "Graphs & MapTracer" --> "Analyse .csv Log File - RPM graphing log Data"
It *is* a beta after all.
#742
Can anyone help me find the address for logging knock sum for a USDM ralliart 53600010. I have mode 23 mostly working but knock sum reads 0 and I am sure I must have a few counts of knock as timing is being pulled. I have been searching this thread but have not found it yet. Thanks.
#749
Does the OBD2 mode work for anyone? My newest laptop is Vista and now the freebie OBD2 scan program doesn't work anymore. When I try and use EvoScan v2.6 in OBDII 96+ mode and click the display DTCs or Clear DTCs it simply doesn't do anything despite saying it connected to the ECU correctly.
An alternative OBD2 scanner program that is Tactrix 2.0 cable and Vista aware would also be fine for now. Mode23 stuff works great for me but it would be nice to know what codes I'm throwing when playing with stuff again.
