Evo X Logging
Old Oct 13, 2009, 10:49 PM
  #811
tephra's Avatar
Send me the ROM mate.
<guess my username :P> @gmail.com
I suspect 53050006 will work - but ill dbl check first
Old Oct 13, 2009, 11:38 PM
  #812
KatoWA's Avatar
You have mail
Old Oct 14, 2009, 01:18 PM
  #813
evo4mad's Avatar
Great NEWS. I have written a device driver for the OpenPort 2.0 and its working great on the EvoScan GPS Navigator. EvoX Support for the EvosCan GPS Navigator is coming soon.
Old Oct 14, 2009, 02:38 PM
  #814
BigT's Avatar
My lc-1 reads completely drifferent vs the gauge. In the log, the value ranges from 5 to 6 vs the gauge being between 15 and 10. Using newest version of evoscan.
Old Oct 14, 2009, 02:49 PM
  #815
derekste's Avatar
are you sure you are on the right com port? for some reason I am given the option of two com ports(4 & 6) w/keyspan USB adapter. one is correct, the other is rich by a few points, but not quite as drastic as yours. perhaps 2 are showing up because one is the keyspan and one the op2?
Old Oct 14, 2009, 07:48 PM
  #816
tephra's Avatar
53050009 is same as 53050006
Old Oct 17, 2009, 11:10 AM
  #817
E6-X's Avatar
thx tephra ... managed to get my 53050006 xml working and updated it with mode23 but on the evoxbase xml cos that's where it was inherited from and now i can see the changes.
just a small contribution (do not know if others has done it but here to help each other out) to all others out there for 53050006 and 53050009 xml with mode23. Just update evoxbase xml in ecuflash. zip file attached below.
will be trying to log via evoscan using JDM mode23 and see if it works out for me.
File Type: zip
Old Oct 17, 2009, 04:19 PM
  #818
tephra's Avatar
DON'T PUT IT IN THE EVO10BASE.XML
The addresses are not the same for every ROM.
Old Oct 17, 2009, 05:40 PM
  #819
E6-X's Avatar
opppssss, sorry, i'll remove from evo10base and put it in my original xml. will keep u posted.
btw, i tried logging with jdm mode23 and all other mode 23's non of them are working out for me, the only 1 that works is EVOX. any solutions ?
thx
Old Oct 17, 2009, 05:47 PM
  #820
BigT's Avatar
I checked which com port it was in and thats where I set it. I'll try another one.
Old Oct 20, 2009, 12:08 PM
  #821
stokEd's Avatar
Nice! Can't wait to use mine.
@Hamish: I bought a GILSSON antenna for the GPS unit and it works like a charm. It takes maybe 30 secs or so to find a satellite. However, something's up with the software on my unit so I haven't been able to really test it much--I'll make a support ticket as soon as I get the chance.
Old Oct 30, 2009, 12:05 AM
  #822
FTY Motorsports's Avatar
just tried this on the 2010 evo x i have here and didnt work?!?! im gonna mess with it tomorrow didnt have much time to mess with it tonight.
Old Oct 30, 2009, 04:11 AM
  #823
newcomer81's Avatar
I have a support ticket in for the 2010 usdm gsr; I have the same problem. The ecu flash definitions aren't fully complete yet either but the mode 23 mappings are available.
Old Oct 30, 2009, 07:03 AM
  #824
Fourdoor's Avatar
You are a step ahead of me Mode23 logging gives mostly gibberish on the 2010 Ralliart. Some of the values log correctly, but not many. I am going to go do a log run with each mode23 variation available and see if some of those match up where the latest mode23 RA EVO doesn't. If anything matches up from the old versions I can just edit the data address into the latest version can't I?
If anyone wants to disassemble the 2010 Ralliart ROM and make a full mode23 logging suite for the 2010 Ralliart, the ROM is available for download here:
http://norcalmotorsports.org/users/b...M_55590006.zip
Thanks,
Keith
Old Oct 31, 2009, 10:46 AM
  #825
ya i tried getting it to work with most of the current configs on evoscan and i got nothing lol just some crazy values haha. i have a pretty complete definition of the 2010 GSR USDM ROM i got from acamus. it has most of the tables that you use when tuning. i just wish i could log the damn thing dont have our dyno yet so still street tuning.
Quick Reply: Evo X Logging
