Evo X Logging
#826
ya i tried getting it to work with most of the current configs on evoscan and i got nothing lol just some crazy values haha. i have a pretty complete definition of the 2010 GSR USDM ROM i got from acamus. it has most of the tables that you use when tuning. i just wish i could log the damn thing dont have our dyno yet so still street tuning.
https://www.evolutionm.net/forums/ec...developer.html
It will allow logging of some of the basic items... it's a great start!
Keith
#827
tephra posted up the codes for the rom but evoscan running any of the mode23's will not work. evoscan needs to be updated for the 2010 addresses is what i mean. atleast i think i mean that haha. i was experimenting last night and none of them work wortha ****. if i could log boost and knock i'd be happy i got my trusty wideband
#828
- Bryan
#830
I know you probably don't have an option to do this on customer cars...but tapping the output into the stock harness = t3h win for logging :-P No additional serial cable to hook up! Wooo hoo!!
verkion
verkion
#831
#832
http://norcalmotorsports.org/users/b...ch/2010_evo10/
2010 USDM Lancer Ralliart - 55590006
http://norcalmotorsports.org/users/b.../tech/2010_RA/
- Bryan
#833
2010 USDM Evo 10 GSR - 55570005
- Bryan
- Bryan
#838
Oh, I forgot to mention, the 2010 GSR & RA share the same MUT addresses so you can select 2010 Mode23 US EVOX RA from the drop down menu for both.
Does anyone have the 2010 MR ROM & XML so I can check those too?
#839
Compressed (zipped) Folders Error
The Compressed (zipped) Folder is invalid or corrupted.
I deleted the file and downloaded it again thinking it was a transfer error, but got the same error.
Keith
#840
Sorry, I don't know why it does that on some PCs, it works fine on my PC and my PC from work.
Just copy & paste the following into your Evoscan data.xml:
Code:
<ecu name="Mode 23 2010 US EVOX RA"> <Mode2 name="Mode2" type="Data List Items"> <DataListItem DataLog="Y" Color="" Display="RPM" LogReference="RPM" RequestID="23808763" Eval="31.25*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="23808784" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A1f" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="2380872e" Eval="(x/4*0.19347)-14.5" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A63" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="2380870d" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="2380867a" Eval="x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="ECT" LogReference="ECT" RequestID="23808653" Eval="x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="IAT" LogReference="IAT" RequestID="2380866d" Eval="x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> <DataListItem DataLog="Y" Color="" Display="Speed" LogReference="Speed" RequestID="238087ff" Eval="x*2" Unit="kph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" /> </Mode2> </ecu>
I downloaded the file, and when I try to open the zipped folder I get the following:
Keith
Keith
