Evo X Logging
Old Nov 6, 2009, 08:36 AM
  #841
Fourdoor's Avatar
Originally Posted by SiC
Sorry, I don't know why it does that on some PCs, it works fine on my PC and my PC from work.
Just copy & paste the following into your Evoscan data.xml:
Just a few notes for USDM users of the code provided by SiC:
In the "Mode23 USA EVOX" and "Mode23 USA RA EVOX" area of EvoScan the formula for throttle positions is "(x-32)*129/255" instead of "x*100/255" Not sure why it is different, and not (yet) sure which one is correct for us to use.
All temperatures provided by SiC are in metric units. For US units use "1.8*x-40" instead of "x-40"
Speed provided by SiC is in kph. For MPH use "1.26*x" instead of "x*2"
Thanks,
Keith
Old Nov 7, 2009, 11:33 AM
  #842
Fourdoor's Avatar
UPDATE:
The Manifold air temperaturelogging doesn't work on my 2010 Ralliart, but everything else provided by SiC works great!
Keith
Old Nov 8, 2009, 07:29 PM
  #843
FTY Motorsports's Avatar
awesome thanks man i will test out on the 2010 GSR tomorrow and i will get the 2010 MR rom up ASAP
Old Nov 9, 2009, 01:13 PM
  #844
nj1266's Avatar
Thanks,
Keith
The TPS code in the 2010 Mode23 is different than the ones in Evoscan Mode23 2008. Should we change the code from "x*100/255" to "(x-32)*129/255"?
Old Nov 10, 2009, 04:07 PM
  #845
Clipse3GT's Avatar
Is there a way to LOG MAF Volts and MAF AIRFLOW in G/S in MODE 23 USA EVO X (for a 2008)?
Old Nov 10, 2009, 04:43 PM
  #846
tephra's Avatar
yes...
53040010:
MAFV:0x808f48:2:x,1023,/,5,*:1
AirFlow:0x8087d8:2:x,2,*,100,/:3
526800XX:
MAFV:0x808f50:2:x,1024,/,5,*:1
AirFlow:0x8087e0:2:x,2,*,100,/:3
Airflow for 526800xx is untested, let me know
Old Nov 10, 2009, 08:33 PM
  #847
Clipse3GT's Avatar
Originally Posted by tephra
yes...
53040010:
526800XX:
Thanks!!!
However here comes in my moment of slight knowledge deficit.
Where do I enter this information. Data edit in EVOSCAN?
Thanks!
Old Nov 10, 2009, 08:39 PM
  #848
tephra's Avatar
thats the format for my logger.
for evoscan just use notepad to edit the data.xml file
just copy one of the current entries (Load is a good one) and modify the address/name and Eval appropriately
Old Nov 10, 2009, 09:57 PM
  #849
Clipse3GT's Avatar
Thanks, I didn't check out this logger yet. I hope I will have a chance to try it out tomorrow and tell if these work.
Old Dec 1, 2009, 12:24 AM
  #850
nj1266's Avatar
Anyone know the request IDs for the 2010 USDM Evo X (55570005) for logging the following parameters:
LTFT- Cruise
LTFT - Idle
STFT
WGDC
WGDC Correction
Thanks a bunch
Old Dec 1, 2009, 01:05 AM
  #851
tephra's Avatar
use the MUT_TABLE and standard MUT request ID's to find them
WGDC correction wont be available.
Old Dec 1, 2009, 01:06 AM
  #852
tephra's Avatar
Old Dec 1, 2009, 01:46 AM
  #853
nj1266's Avatar
If I knew the request IDs for logging the parameters then I would not have asked. I would simply copy the code from the 08 xml and change the request IDs to those of the 2010, save, and test the logging on a 2010 car.
Old Dec 1, 2009, 04:24 AM
  #854
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
For example in 55570005
MUT Table is at 3f244
now when you look at the table in Ecuflash and you know the RequestId from evowiki you can write
logging item in EvoScan.
Example:
0D LTFTMid Fuel Trim Mid (LTFT) % (x-128)/5
Request number is 0D in MUT table so you take value from MUT0x row and D column which is 804575, now you take it and write mode23 EvoScan item as 23804575 using scaling from evowiki
Hope it helps.
Old Dec 1, 2009, 04:43 AM
  #855
tephra's Avatar
yes sorry NJ I should have been more specific.
once you find the MUT_TABLE (as per CT9A) you can then use that as a common reference point for most useful memory addresses
ie MUT0F is ALWAYS the STFT, so in ANY rom if you find the MUT_TABLE then you can find MUT0F easy enough. and therefore you can see the memory address for MUT0F, which will the the STFT
Quick Reply: Evo X Logging
