Evo X Logging
Old Dec 1, 2009, 04:46 AM
  #856
tephra's Avatar
yes sorry NJ I should have been more specific.
once you find the MUT_TABLE (as per CT9A) you can then use that as a common reference point for most useful memory addresses
ie MUT0F is ALWAYS the STFT, so in ANY rom if you find the MUT_TABLE then you can find MUT0F easy enough. and therefore you can see the memory address for MUT0F, which will the the STFT
Old Dec 2, 2009, 05:41 PM
  #857
tonyboy's Avatar
hi,
one question, i'm not sure if i'm seeing it right..but i got the 55570005 xml file from GST's link (i assumed that it is ok to download/copy )...so i used that and applied the necessary changes for the mode 23 for this specific xml file...i noticed that there are no mivec maps...do i have the right xml file? TIA
anthony
Originally Posted by GST Motorsports
2010 USDM Evo 10 GSR - 55570005
http://norcalmotorsports.org/users/b...ch/2010_evo10/
2010 USDM Lancer Ralliart - 55590006
http://norcalmotorsports.org/users/b.../tech/2010_RA/
- Bryan
Old Dec 2, 2009, 05:44 PM
  #858
GST Motorsports's Avatar
You need to download the Base file as well.
- Bryan
Old Dec 2, 2009, 05:46 PM
  #859
newcomer81's Avatar
- Bryan
1st time i saw a link to the 2010 gsr files, thanks for making them available
Old Dec 2, 2009, 06:54 PM
  #860
tonyboy's Avatar
- Bryan
Hi Bryan,
i downloaded the evo10base from your url...and i still don't see the mivec maps...i had a back up of the evo10base from ecuflash itself...i reverted it back now i can see the mivec maps...are there any important modifications in the evo10base from your evo10base? TIA
anthony
Old Dec 14, 2009, 10:45 AM
  #861
Airboy's Avatar
trouble logging 2009 EVOX MR
Car: 2009 EVOX MR (54070007)
I modified the xml for 54070007 per the 1st post and enabled mode23. Evoscan 2.7 beta can connect with openport 2.0 cable but the data values are not correct, other than RPM and ign advance.
Am I missing a file for evoscan? Any other logger that would work?
Thanks.
Old Dec 14, 2009, 09:56 PM
  #862
Airboy's Avatar
I searched for posts by CT9A and couldn't find anything relating to MUT_TABLE. Can I find it using just a hex editor or do I need IDA?
Old Dec 14, 2009, 10:02 PM
  #863
tephra's Avatar
did you work out mode23 locations for your romid yet?
MUT_TABLE can be found using a hex editor... It is easier with IDA.
Old Dec 14, 2009, 10:21 PM
  #864
Airboy's Avatar
No I haven't. That is why I want to find the MUT table so I can start from some known items from that wiki page.
Old Dec 14, 2009, 10:25 PM
  #865
tephra's Avatar
Well your going to need mode23 addresses anyways.
If you have a 100% stock ROM you can email it to me <myforumname> @ gmail.com and when I have time I will give you the MUT_TABLE + mode23 addresses...
Old Dec 14, 2009, 10:32 PM
  #866
Airboy's Avatar
I thought you meant if I was able to sort out the memory address for the different items. I found the mode23 address at the beginning of this thread so that is taken care of. I just sent you the stock ROM. Thanks.
Old Dec 15, 2009, 09:13 PM
  #867
Ah10's Avatar
Originally Posted by acamus
For example in 55570005
MUT Table is at 3f244
now when you look at the table in Ecuflash and you know the RequestId from evowiki you can write
logging item in EvoScan.
Example:
0D LTFTMid Fuel Trim Mid (LTFT) % (x-128)/5
Request number is 0D in MUT table so you take value from MUT0x row and D column which is 804575, now you take it and write mode23 EvoScan item as 23804575 using scaling from evowiki
Hope it helps.
AWESOME! the explaination helps alot!
Old Dec 16, 2009, 06:54 AM
  #868
tsitalon1's Avatar
Hey guys is 2.7beta still the most current version? I haven't been following lately.
Old Dec 19, 2009, 08:31 PM
  #869
Ah10's Avatar
is there such a thing as 2-byte rpm for 55570005 ecu id? anyone has the request ID for logging purpose?
Old Dec 24, 2009, 12:00 AM
  #870
lpy2009's Avatar
hi tephra,
seeing that your from melbourne , awesome stuff
i'd like to ask if theres any tuners/workshops that have stardard working/tuning on the Evo X MR and the TC-SST ?
thanks so much
Quick Reply: Evo X Logging
